67 Project Thread
Old Nov 17, 2009 | 09:27 PM
tcrote5516's Avatar
tcrote5516
Default 67 Project Thread
Just moved this from general tech.
Thought I would share my project thread. Its a 67 Coupe I bought this past June. Great running/driver for $5,000 and most importantly a solid canidate for a restomod. Very minimal metalwork needed, no real rot at all. I'm starting with the engine and engine compartment.
Got the inner fenders/rad support striped and coated.
Engine: 68' 302 with 351W heads, high duration cam and a bunch of shiny goodies. Mated to a T5 and a 9" rear.
Headman long tube headers:
st about wrapped up with a high rise manifold.
Still need a chrome alt, aluminum rad/hoses and pulley kit...ut you get the idea.
Old Nov 17, 2009 | 11:12 PM
darkngtz's Avatar
darkngtz
that is exaclty what my 67 coupe looks like....to a "T" except ur engine is shinier and bigger lol
Old Nov 18, 2009 | 04:12 AM
tx65coupe's Avatar
tx65coupe
Looks like a great car. Nice project.
Old Nov 18, 2009 | 05:53 AM
LynnBob Mustang's Avatar
LynnBob Mustang
Awesome transformation!!
What kind of ignition are you running?
Lynn
Old Nov 18, 2009 | 05:39 PM
coolhnd9's Avatar
coolhnd9
That engine bay is looking great!
Old Nov 18, 2009 | 06:07 PM
Green69's Avatar
Green69
curious, what paint/finish did you use for the engine bay? It looks like it has some texture?
Old Nov 19, 2009 | 09:08 PM
tcrote5516's Avatar
tcrote5516
Its a trick I learned from my last resto. I use a sealer, on this one I used high build primer and removed some factory indents. Then top coat with a bedliner spray through a fine spray tip. It takes a gentle trigger finger to get the fine texture (rather then big blotches) but it gives it a factory type look that resists scratches.
Thanks for the compliments...not sure how you guys would take such a departure from the classic look of what you find undermost of these years hoods.
Now if I canjust get that friggin intake manifold to seat right. With the gaskets in place its getting bound up on the heads about 1/4" from dropping down. PITA
Old Nov 19, 2009 | 10:05 PM
cdan03's Avatar
cdan03
wow seems like a great project. i think you got a good deal for 5000. the eninge looks sick any numbers on it? the eninge bay looks great to, did you paint it with the engine out?
Old Nov 25, 2009 | 07:28 PM
tcrote5516's Avatar
tcrote5516
What do you mean by any numbers on the engine?? Power or actual block castings?
I found it easy enough to paint once stripped to the bare block and didnt bother pulling it.
Here's a closeup of the headers:
And a shot of the stripped interior, replaced floorboards, refinished and sealed:
Old Nov 25, 2009 | 09:12 PM
cdan03's Avatar
cdan03
what are some specs on the motor?
