Backup LIghts
Old Nov 19, 2009 | 02:58 PM
BeastMachine67's Avatar
BeastMachine67
Default Backup LIghts
Hey guys,what's up? I cant seem to get my reverse lights to work...infact I dont think they ever worked since I owned the car. Any suggestions on where i should start troubleshooting??
It use to be an automatic but, now it's a stick ( if that helps)
Old Nov 19, 2009 | 03:02 PM
Adam's Avatar
Adam
I'm in the same situation - they have never worked. My mechanic said I'm missing the Back Up Light Switch (click link).
Old Nov 19, 2009 | 03:05 PM
2+2GT's Avatar
2+2GT
If you have the factory 4-speed shifter, the switch looks like this:
Old Nov 19, 2009 | 03:17 PM
urban_cowboy's Avatar
urban_cowboy
With a Hurst shifter, they are next to impossible to keep adjusted correctly. It is very common for the mounting bracket to get bent thus rendering the switch inoperable.
Old Nov 19, 2009 | 03:19 PM
ChesterKaup's Avatar
ChesterKaup
Usually a broken or missaligned switch.
Old Nov 19, 2009 | 05:56 PM
BeastMachine67
any ideas where i should start looking though? I heard that the wires for the back-up lights are right next to the wires from the netural safety switch
Old Nov 19, 2009 | 06:12 PM
Gun Jam's Avatar
Gun Jam
Yes
If applicable you should start by physically inspecting said switch shown in above photo... IF N/A then specify transmission type/make
-Gun
Old Nov 19, 2009 | 06:13 PM
BigIron22's Avatar
BigIron22
the back-up light wires are in the same square plug as the neutral safety switch on the engine side of the firewall under the export brace. ( that is if someone hasn't cut the plug off to spliced the n.s.s. wires together.)
Old Nov 19, 2009 | 06:21 PM
2+2GT's Avatar
2+2GT
Not likely. manual trans Mustangs don't have a neutral safety switch.
Old Nov 19, 2009 | 06:24 PM
2+2GT's Avatar
2+2GT
Yeah, Ford spliced the NS wires together, at the plug end of the BU wiring harness.
