Backup LIghts
Old Nov 19, 2009 | 06:40 PM
BeastMachine67's Avatar
BeastMachine67
Originally Posted by 2+2GT
Not likely. manual trans Mustangs don't have a neutral safety switch.
LOL no guys here's the thing..the car use to be an automatic, I took it out and dropped in a T-5 manual. BUT when it was an automatic I dont think the back-up lights where even working
Old Nov 19, 2009 | 07:34 PM
2+2GT's Avatar
2+2GT
Well, when you changed in the T5, did you connect the BU switch on the trans?
Old Nov 19, 2009 | 08:26 PM
BigIron22's Avatar
BigIron22
Yeah, Ford spliced the NS wires together, at the plug end of the BU wiring harness.
if you read the original post he states it was and AUTOMATIC car and it was converted to manual.
so the n.s.s. would need to be bypassed somehow or turned into a clutch pedal switch like modern cars.
Old Nov 19, 2009 | 08:49 PM
BigIron22's Avatar
BigIron22
found this pic of the connector for the back up lights at the firewall maybe it will help you get started. a little different than my 70's single plug. looks like it is 2 separate plugs for n.s.s. and back up lights if you car runs one of these have been bypassed. if you jump the 2 pins on other one with your key on your back up lights in theory should illuminate.
Old Nov 20, 2009 | 09:16 PM
BeastMachine67
70stangguy, your the the man! You're definately getting what I'm posting, I'll jump those to pins tommrow and see what happens
Old Nov 21, 2009 | 07:02 AM
2+2GT's Avatar
2+2GT
I did read his post, and more people than him read it, I'm pointing out how FORD solved the problem.
There is no need to bypass his C4 NS switch. Since he removed the trans, it's on the garage floor, on the side of the trans. He will need to bypass the connectors, which is why I pointed out how Ford did it. He could do this himself in about two minutes.
Speaking of which, the NS on later manual cars was on the TRANS, not the pedal. Which means his T5 has a NS switch on it, if he cares to hook it up. That might take a whole half hour, mostly from crawling under the car to connect it.
Old Nov 21, 2009 | 03:39 PM
BigIron22's Avatar
BigIron22
maybe this will help if you are still having problems. says it is for a 66 but it shouldn't be that much different. if you jump the plug and nothing else is wrong the back-up lights should illuminate. if they do you just need to connect the wires at the plug to the trannys back-up light switch. easy way is to get the connector from a 5 speed fox body.
if they dont work after jumping the plug you will have to find where the power is being lost. blown fuse, bad bulbs, bad grounds, broken wire or wires, loose connections, or corrosion at the connections. good luck.
Old Nov 22, 2009 | 07:42 PM
BeastMachine67
thanks, I gonna have to trace where the problem is coming from because I jumped those to terminals and got nothing so, I'm gonna see if I can print out that electrical diagram and trace the problem
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
