wheels
Old Nov 20, 2009 | 02:05 PM
cdan03's Avatar
cdan03
Default wheels
i have been looking to find out what the largest size tire can be put in the back of a 1966 mustang coupe. i have only seen up to 255's in the rear i am thinking 16 or 17 inch wheels for the street and would like 275 in the rear. i would prefer to not tub the back end, but just out of cuiousity how much would that cost. I would also like to get a 10 in slick in the back when ever i go to the strip in the future
Old Nov 20, 2009 | 02:50 PM
tx65coupe's Avatar
tx65coupe
I don't think 275 will work.
I have 235 60 15 on the rear of my 65.
I think there is a little more room on mine, so 255 might work.
Take a look at this.
http://www.mustangbarn.com/tire.html
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
Old Nov 20, 2009 | 03:12 PM
JDraper's Avatar
JDraper
Depends upon the wheel offset and if you want to roll your fender lips or not. We run 225/60-15's on the back of our '66 on 15 x 7 rims with 3.875" backspacing and it's a tight fit to the fender lips (Ours aren't rolled).
Old Nov 20, 2009 | 06:29 PM
Iskwezm's Avatar
Iskwezm
275's fit fine as long as the back isnt lowered excessively. I have 17X8 with a 4.75 BS. I couldve went a little wider on the wheels and changed the offset. I just got a pair of 26X11.50X17 et streets so i'll see how those fit.
Old Nov 20, 2009 | 06:34 PM
bredn65's Avatar
bredn65
I run 245/50/16 on the back of mine w/4.5. Had to roll the fenders though as the car is lowered a tad.
Old Nov 20, 2009 | 08:13 PM
dodgestang's Avatar
dodgestang
With 17x8 rims with 4.75 backspacing my experience (and I believe others has been):
255s - roll the lips and you are pretty much done:
275s - roll the lips and if your rear aint centered...they aint fitting. Also required hammering inner wheel house slightly (after I perform modifications to center my rear properly)
Old Nov 20, 2009 | 09:29 PM
cdan03's Avatar
cdan03
thanks for all the info. i am glad to see that 275 can fit without tubbing the rear end. 275's is near a 11 inch tire so when ever my car sees strip time i won't have to worry about hooking up.
dodgestang:
so all your saying is that 275s fit as long as the wheel is centered, lips are rolled and the inner wheelhouse hammered a little bit it will work? did you lower the car any and what are is the sidewall height, 45's?
Old Nov 21, 2009 | 07:21 AM
JDraper's Avatar
JDraper
You might also want to consider how much rotating mass is in the larger wheels. You might get better results with a slightly narrower tire/wheel combo that has a sticker tire. At one point, I ran 315's on the back of my Mach but found that I was quicker off the line and accelerated better with a 275 tire that sticks better. The larger tire and rim combo's rotating mass more than offset the traction advantage.
Old Nov 21, 2009 | 07:33 AM
dodgestang's Avatar
dodgestang
dodgestang:
40 series tires and the car is lowered.
Personally I wouldn't get too bent out of shape trying to run 275s on the 65/6. On an 8 inch rim they will have the same contact patch as the 255. The only reason I have 275s is because those are my drag radials for the strip.
Old Nov 21, 2009 | 09:45 AM
cdan03's Avatar
cdan03
well i am planning on running street/drag radials for the street so i can get some traction if i get on it. and i would do slick for strip.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
