Car dies in the same spot every morning!!!
#22
No, the dashpot sits behind the throttle lever and keeps the throttle from snapping shut when you get off the gas pedal. It has a spring and a diaphragm in it and it slowly brings the lever back to the idle position.
#23
no, don't buiy a new carb unless you were planning for that anyway. ( i wouldn't for the moment)
the dashpot only slows down the throttle on the way to close position. that's all it does.
I believe the problem to be the combination of closed throttle and corner (bend), so the very first thing that needs looking at is the float level and the filters
#24
Like I said, get a new carb. New carbs come with any kickdown linkage you might need, and a 2bbl changeover is easy. A new carb will work great, give you more power, and be more responsive when you tap the gas pedal. If you don't do it now, just remember this option for the future in case you're faced with rebuilding the 2100 again. It's an EZ switch for a couple hundred bucks.
CP
CP
i guess i dont get why a person would replace 1 carb with a new carb when the 1 they have can just be tuned and would work just fine.
ive got the original 2100 on my '65. only time ive EVER had an issue was when i parked in a friends driveway at a steep incline. i had to put it in neutral and coast down it to more level area becuase the fuel pump couldnt pump enough gas in haha
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
