Gas Leak - question
Old Dec 10, 2009 | 11:02 PM
64.5stanger's Avatar
64.5stanger
Originally Posted by hiboostwoody
Me too. Nothing like an armpit full of gas to make your day extra special.
only thing worse than a armpit full is an a/crack full of gas. Ive never experienced this,but my old-man fliped his quad and got some gas in his crack, not pleasnt from what ive heardhead banger
Old Dec 10, 2009 | 11:59 PM
THUMPIN455's Avatar
THUMPIN455
I got a body wash of gas one afternoon in a parking lot under a Tarus wagon. I siphon the gas out now, every time. It doesnt take much to light you up like an F4 dropped a load of napalm on you. Its not the way I want to go out, writhing in agony from a spark... gives me shivers to think about it.
Old Dec 13, 2009 | 10:47 AM
WarrenW's Avatar
WarrenW
Question
Since it finally stopped raining, I was able to get under the car and clean it. Then I noticed it was not leaking at the hose although I am going to replace it. It is the sending unit/fuel connector. The tank and sending unit is not old at all so I figure I can replace the o-ring gasket and the retaining ring and that should fix it.
Has anyone used any other sealer when installing this? Or just use the o-ring gasket? I want to make sure it does not leak again if at all possible!
Thanks!!
Warren
Old Dec 13, 2009 | 10:07 PM
hiboostwoody's Avatar
hiboostwoody
Don't use any sealer. Just use the o-ring.
Old Dec 14, 2009 | 09:14 AM
stephen.osborne1's Avatar
stephen.osborne1
Thanks!!
Warren
Make sure the O-ring is the right kind... should be "square" not round... Also, make sure it stays put when you turn the twist lock thing (can't remember the real name) that keeps the sending unit in place... I replaced my sending unit last year and the o-ring "slid" when I twisted the lock, and it stretched the O-ring out... So I had to find another O-ring after it leaked. And the auto shop gave me a round one, so it leaked too... on the third try, no problems. Should have been a pretty easy fix...Shoulda known better
Old Dec 14, 2009 | 02:43 PM
WarrenW's Avatar
WarrenW
I ordered the parts today from MustangsUnlimited and the picture showed the o-ring gasket as round. I ordered a couple extra just incase something went wrong.
Old Dec 15, 2009 | 01:24 AM
tx65coupe's Avatar
tx65coupe
It should be round, but flat like a washer and not round like a tube.
algregory
Sep 11, 2015 11:44 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
