Parking lights on question
Old Dec 23, 2009 | 11:49 PM
nba1341's Avatar
nba1341
Default Parking lights on question
When I turn my parking lights on, the first click of the headlight switch is this suppose to make my turn signals no longer function? When I turn them on it makes my right turn signal dash light stay on and the right turn signal no longer functions correctly. The left stays off and still functions.
So which is the way its suppose to be and which do I need to fix?
Old Dec 24, 2009 | 12:52 AM
dirtydave289's Avatar
dirtydave289
They are still supposed to work..at least the signals in my 66 work no matter what lights you have on
Old Dec 24, 2009 | 04:58 AM
2+2GT's Avatar
2+2GT
Sounds like a bad ground at the lamp. You should also check to see if maybe the bulb is installed improperly.
The 64-67 front parking lights are only on in the park position on the switch. When the headlights come on, they go off.
Regardless, the turn signals should always work.
Old Dec 24, 2009 | 08:01 AM
Oxnard Montalvo's Avatar
Oxnard Montalvo
+1.
You very well may just have a bad bulb. Or the wrong one.
First thing is to make sure you have the right bulb in there and that it's good. Does the right side light up at all? Is this a new problem?
Either swap the bulbs and see if the problem switches sides, or go buy 1157 bulbs and put a new one on the right side.
Here's the list for what bulbs go where.
Auto Lamp Replacement Guide, 1965 Ford Mustang.
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 2, 2015 08:40 PM
cbird1177711
Sep 2, 2015 04:12 PM
