Lower dash removal
Old Dec 28, 2009 | 06:16 PM
Stangman70's Avatar
Stangman70
Default Lower dash removal
How do you remove this on a 70 coupe? Do you need to remove the steering column as well?
Old Dec 28, 2009 | 06:56 PM
2+2GT's Avatar
2+2GT
Theoretically. In actual practice, I have detached it from the pedal support, removed the firewall bolts from the seal flange, and lowered it to the floor.
The trickiest part is the RH dash panel, the one that matches the instrument panel, goes in and out with the pad.
Old Dec 28, 2009 | 08:35 PM
4reboy's Avatar
4reboy
By lower dash you mean the metal frame, correct? Well regardless, you don't need to remove the steering column to remove any of the dash. There's bolts on each side of the dash holding it to the car, two brackets near the middle, and I believe one bolt going into where the gauges would be. It's really simple, just find al the bolts/brackets and lift it over the column and out through the car. I've done it twice to my car and took out the dash on my dad's 69 as well, it only takes me 30-50 minutes.
Here's my car, no dash, column in.
Old Dec 28, 2009 | 09:50 PM
2+2GT's Avatar
2+2GT
No soundproofing on the underside of the cowl? Ford did.
Old Dec 28, 2009 | 11:03 PM
4reboy's Avatar
4reboy
Ford didn't on my car. I forget if I did end up putting some up there or not, I wasn't completely done in that photo.
robcy
Suspension
Oct 27, 2015 11:14 PM
rksnow1
Sep 14, 2015 08:46 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
wawagner82
Sep 13, 2015 09:02 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
