antifreeze question
Old Dec 31, 2009 | 08:03 PM
cobramustangboy's Avatar
cobramustangboy
Default antifreeze question
I got my 65 fastback out yesterday and went for a good 2 hour ride, when I got back, nothing, no leaks, all good; but I came out this morning and there was a puddle of antifreeze under the car...it looks like it dripped out of the top of the radiator where it connects via tubing to the motor, I checked the level before taking it out yesterday, and it was about an inch below the inside ring of the filler....is that too much fluid???? if I just take it around the block for a 15 min ride or so, no problems...it just seems to happen after long rides and the motor cools down.....whats going on??? thanks fellas
Old Dec 31, 2009 | 08:09 PM
tx65coupe's Avatar
tx65coupe
Could you be more specific about where you think it is leaking from?
It sounds like your saying that the overflow/expansion line is leaking. Is that what your saying?
If your not running an expansion tank then the coolant will be lost on the ground. Most cars of this era did not come factory with one.
Old Dec 31, 2009 | 08:13 PM
cobramustangboy
at the top of the radiator where the large tube from the top of the motor comes into the radiator....I hope that helps
Old Dec 31, 2009 | 08:16 PM
tx65coupe's Avatar
tx65coupe
Oh, So you think the upper radiator hose is the culprit? Is it a newer hose? It may be that the clamp is not staying tight.
Old Dec 31, 2009 | 08:33 PM
cobramustangboy
its not a new hose, but i took it off today and reinstalled, making sure everything was tight, I'm gonna put some more anitfreeze in the radiator tomorrow, but I just don't wanna overfill it and have the same problem
Old Dec 31, 2009 | 08:56 PM
nba1341's Avatar
nba1341
as long as you have an overflow tank when the metal expands it will push the excess into the tank
Old Dec 31, 2009 | 10:09 PM
2+2GT's Avatar
2+2GT
This is normal. Do not fill above this level.
Old Dec 31, 2009 | 10:36 PM
setx69fastback's Avatar
setx69fastback
I was having a problem with a small leak around the thermostat housing as the engine cooled, wasn't even a gasket (or a thermostat for that matter).
Old Dec 31, 2009 | 11:13 PM
2+2GT's Avatar
2+2GT
Not good on both counts. You need the Ford 190° stainless 'stat with the air bleed.
Old Jan 1, 2010 | 08:18 PM
cobramustangboy
I filled the radiator back up with some antifreeze this afternoon, took it for a spin, and didn't see any leaks after putting back in the garage....I'll check tomorrow morning, but like I said, I just went through and made sure all the hosing was tight and whatnot
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
