Engine shut off on me several times today
Old Jan 4, 2010 | 11:08 PM
TheMarco's Avatar
TheMarco
Default Engine shut off on me several times today
So I took a long (130 miles) trip yesterday with my 68 and everything was absolutely fine. No issues or whatsoever, running like a new car.
Today all of a sudden I had the car shut off on me three times. All three times it happened very shortly after departing. I routinely always let the car idle for a bit before I take off so it had at least somewhat warmed up.
The shutting off happened as I stepped on the gas.
Anyone have an idea what could be causing this all of a sudden?
Old Jan 4, 2010 | 11:43 PM
Gun Jam's Avatar
Gun Jam
did it shut off like turning the key off? or did it bog down then rev up and die or stumble?
-Gun
Old Jan 4, 2010 | 11:55 PM
TheMarco's Avatar
TheMarco
It just died as if I turned the key off. Started right up again afterwards without any hiccups or other problems.
Old Jan 5, 2010 | 12:38 AM
Gun Jam's Avatar
Gun Jam
sounds like it could be ignition.
Are you running points and what type of coil?
-Gun
Old Jan 5, 2010 | 01:30 AM
TheMarco's Avatar
TheMarco
I had an electronic ignition module installed a while ago. Does that help?
Old Jan 5, 2010 | 09:05 AM
kalli's Avatar
kalli
i had similar issues a few times.
Once it was a selfrouted (complete **** job) wire to ignition coil from ignition switch that dropped on header, burnt and shorted out. Only on accelleration
The other time it was a pertronix distributor (new). The ground cable for the module was attached to the screw that holds that vacuum canister. That was loose from factory. Any dramatic change in vacuum->car died ... was hard to find. the kinda loose canister gave that away
Check all your wiring ...
Old Jan 5, 2010 | 10:18 AM
TheMarco's Avatar
TheMarco
Thanks kalli!
Good news so far I guess. This morning I decided to take my daughter to school in the Stang just to test things a bit. Before leaving I made sure all 8 connectors were tight on the ignition and the other wiring was ok too. Some were a bit loose so I pushed them back on tight. Played with the throttle a lot and didn't have any issues this time.
Fingers crossed!
Old Jan 5, 2010 | 10:33 AM
rbinck's Avatar
rbinck
I had that problem once many years ago and it turned out to be a frayed capacitor lead in the distributor. When the spark advance would activate the wire would ground and stall the engine as though you turned the key off.
Old Jan 5, 2010 | 12:34 PM
kalli's Avatar
kalli
Originally Posted by TheMarco
Fingers crossed!
best of luck!
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
