67 PS Outer Tie Rod
Old Jan 13, 2010 | 12:21 AM
67 newb's Avatar
67 newb
Default 67 PS Outer Tie Rod
I got this with the Granada disc swap. Is it suppose to go on the driver side or passenger?
Old Jan 13, 2010 | 12:27 AM
4reboy's Avatar
4reboy
You only got 1 tie rod? if you have new discs and need new tie rods you will need both of them...
Are you sure you don't need the idler arm?
Old Jan 13, 2010 | 05:20 AM
2+2GT's Avatar
2+2GT
Yes, the 67 PS Mustang does not require different outer tie rod ends. However, you will need to go to the auto parts store and get a PAIR of 1977 Granada outer tir rod ends. They have really big pins, bigger even than the 70-73 Mustang.
Another reason I don't like Granada brakes.
Old Jan 13, 2010 | 10:46 AM
67 newb's Avatar
67 newb
I got both along with the Idler arm. They did look the same, and are larger than the originals. I just wasn't sure if one in particular is suppose to go on the RH or LH side.
Old Jan 13, 2010 | 12:10 PM
4reboy's Avatar
4reboy
The tie rods should be able to go on either side, they're interchangeable. The idler arm just bolt off and bolt back on, and be sure to torque everything down appropriately and put in the cotter pin.
Old Jan 13, 2010 | 02:20 PM
Silverblade's Avatar
Silverblade
When i ordered new tierods from john at ORP he gave me 70 or 71 outers for my 67 because I have the granada swap
Old Jan 13, 2010 | 02:50 PM
2+2GT's Avatar
2+2GT
He did you a disservice, because the 70-73 outers are smaller than the Granada OTR.
jrrhd73must
Oct 2, 2015 09:17 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
gagemcc
Sep 22, 2015 09:43 AM
