Headliner Wrinkle Woes
Old Jan 20, 2010 | 09:05 PM
IdahoMustangMan's Avatar
IdahoMustangMan
Default Headliner Wrinkle Woes
I'm about to pull what's left of my hair out.
I'm doing a ground-up restoration of a 67 Coupe. There is little I haven't been able to handle but I've met my match installing a wrinkle-free headliner. Three different books (including motors manual) and three different ways to install. I've finally settled on middle out (starting with bows 2 & 3 and working toward front, back, and sides). Wrinkles remain.
It's 40 degrees in my garage (winter in Boise) which doesn't help, but there has to be a way to do this. Motors manual speaks of steaming an installed headliner to "shrink" the wrinkles out. Anyone had luck with that (or other suggestions)?
Old Jan 20, 2010 | 09:27 PM
onlymustangfords's Avatar
onlymustangfords
Are you doing it with the windshield out? My understanding from the top shops is that, thats the way you're supposed to install them, for no wrinkles.
Also think I remember an article on Mustang Monthly's site with pictures.
Its probably worth a look.
Good Luck
Old Jan 20, 2010 | 11:12 PM
IdahoMustangMan
Windshield and backlight both out. Will check Mustang Monthly. Thanks for suggestion.
Old Jan 21, 2010 | 12:09 AM
boogerschnot's Avatar
boogerschnot
I did mine with my buddy who does upholstry for a living and we did center front and rear first and then worked the rear outwards left and right from center using clips and glue. then front the same way with contact. Then did the sides which were held in with the windlace and contact. And then I let it sit out in the parking lot on hot days with the windows rolled up. Ive got only about 3 small wrinkles in the bends at the top of the rear window.
Old Jan 21, 2010 | 01:55 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Make sure you have the two little wires that hold the rear most bow from moving forward installed. If they are not in it will be a nightmare. Once those are in you start stretching from the front. The stretch from the sides making sure the headliner is pretty much centered. Get all of that done, glued and inplace and then move to the back. Stretch it rearward while working the aprons in the back. Healiners suck.
Old Jan 21, 2010 | 05:51 AM
2+2GT's Avatar
2+2GT
You got it. Hook the two wires at the rear, pull the center front, working toward the front corners. Use headliner glue, and many small clamps, or short pieces of windlace to hold it on. Then repeat at the rear. Then the sides. And yes, eve the pros get mild wrinkles, use a steamer to get them out.
Old Jan 21, 2010 | 10:20 AM
mortman's Avatar
mortman
I am getting ready to tackle this my self...Question, how do you tell which bow belong in what position if i did not mark them upon removal? and which hole do you use top or bottom?
Thanks
Old Jan 21, 2010 | 10:35 AM
2+2GT's Avatar
2+2GT
Thanks
They were color coded at the factory, but if that is no longer visible, just install them bare until it's obvious they are in the right place, mark them, and slide them into the headliner.
Old Jan 21, 2010 | 10:42 AM
ventagemod67's Avatar
ventagemod67
I installed mine on a day that was about 90 degrees.. gotta love Mississippi.. I started mine in the center.. worked to the rear.. tugged and tugged and tugged.. then did the front. Then she sat out side for two days with the windows up in 90 degree weather. I had some pretty bad wrinkles that came out eventually and now I can hardly notice them.
Old Jan 22, 2010 | 11:16 PM
IdahoMustangMan
Great responses all, thanks.
Process I'm using is similar... back pins in place and stretch forward. Working sides next, out from the middle. I pulled my glue seams out front and back because too many wrinkles... will be redoing that again this weekend. Friend lent me a clothing steamer so will try that when all is glued. No 90 degree weather in Idaho this time of year.
Mortman, I can answer your bow question (assuming your 68 is the same as my 67). Mine still had factory paint so it was easier. Bow 1 (near windshield) has no paint, 2 is red, 3 is white, 4 is blue (cute, I know). If paint is gone, 1 and 2 are exactly the same size but 2 has a flat top. 3 has a slightly longer extension than 2 (and is also flat on top). 4 is easiest to recognize because it has the longest downward extensions.
As for holes, factory gave installers choices. Default choice is the hole closest to the roof (to give maximum headroom). I took pix of mine when I disassembled and the lowest hole was used for all. When I went to install, given that I had put up 1/2" insulator pad, I was forced to use the same lowest holes.
Wrinkles I haven't solved yet but I hope that helps you get your bows straight. T
