Suspension kit
Old Jul 24, 2005 | 01:34 AM
eZ's Avatar
eZ
Default Suspension kit
what do you guys think of this suspension kit? has any one used thier products?
http://www.laurelmountainmustang.com/index-1024.htm
Old Jul 24, 2005 | 01:48 AM
Scott H.'s Avatar
Scott H.
Default Made in the USA?
Ask them if it's made in the USA and if it utilizes the same gauge steel as original. Napa sells Napa branded USA made Moog components that are really nice. I have no idea what the cost is though.
Also look real close at the "Roller" spring purches. I've seen two versions. One with a bronze bushing and one with sealed bearings. Not a negative post anywhere that I've found. All the posts I've seen people rave at how much difference they make.
Old Jul 24, 2005 | 02:13 AM
eZ's Avatar
eZ
Default RE: Suspension kit
i see the link didnt really work but here is what they are selling
Our Upper and Lower Control Arms have riveted ball joints - like original - for the correct look
1965-73 Super Suspension Kit
Available in Polyurethane or Midolyne
Midolyne-a thermoplastic, appearance of rubber-but stiffness and long life of polyurethane
* Master Suspension Kit #1 (see below for contents)
* Coil Springs (add $12. for 1" drop)
* KYB Shocks
* 1" Front Sway Bar
* 3/4" Rear Sway Bar w/ all Mounting Hardware
* Leaf Springs Kit, Includes (2) Shakles, 1 Set U bolts & 1 pair I bolts
* Tie Rods - (4 piece)
* Adjusting Sleeves - Tie Rods (1 pair)
* Idler Arm
* FREE WITH THIS KIT your choice curved black Monte Carlo Bar or Black Export Brace - Upgrade in Chrome MC Bar $10.00, Export Brace $14.00
**Add $35. for High Performance or 1" Lowered Mid Eye
**Add $14. for High Lift Option
**Add $15. for one pair, 1" Drop, Powder Coated Coils
****Please specify if your car came w/ a factory swaybar - you will need rear bar kit # 990, to avoid drilling holes
$769.00
master suspension kit #1 includes
Kit Includes:
2 Complete Upper Control Arms, with Ball Joints & Shafts installed, 2 Lower Control Arms, w/ Bushings & Ball Joint, 1 Set Strut Rod Bushings with washers & hardware, 1 Pair End Links, 1 Pair Sway Bar Bushings w/Brackets (specify sway bar & engine size), 2 Coil Spring Insulators and 2 Coil Spring Saddles....LifeTime Guarantee!!
Old Jul 24, 2005 | 05:21 AM
68COOP's Avatar
68COOP
That's a good deal, I paid 325 for just the leafs and the install kit. My next major resto is my front end. Then disc brakes, then... It seems to never end. Good luck.[8D]
Old Jul 27, 2005 | 03:37 AM
speedjunkie's Avatar
speedjunkie
dont forget about shipping. i bought that kit with the 1" drop on both ends and that brought the price to 824.00 and then the shipping another 147.00. thats to oregon so to cal. it will be in that ball park. and you will still need the center link it dos'nt come with the kit. but even with the shipping from the other side of the country, piecing it out from closer shops will cost you more. i spent 2 weeks looking and pricing before i bought the kit and i was happy with the quality of the parts.
Old Jul 27, 2005 | 03:26 PM
eZ's Avatar
eZ
center link?
Old Jul 28, 2005 | 08:14 AM
Fastback Guy's Avatar
Fastback Guy
I've used a TON of Laurel Mountain. I put the master kit on my car and was impressed with the quality. Shipping is pricey just because of the weight. I've used them SEVERAL times and am always impressed.
Old Jul 28, 2005 | 05:17 PM
eZ's Avatar
eZ
thnx for the replies..ill put it on order
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
marc954
Sep 29, 2015 11:18 AM
