Lean and rich
Old Jan 23, 2010 | 10:47 PM
1965screamer's Avatar
1965screamer
Default Lean and rich
So I had the spark plugs out today and noticed the drivers side plugs looked like they have been running lean then when I pulled the plugs on the other side they were all black like its running rich on that side. I'm running an air gap dual plane manifold and a Holley 750cfm carb. Since it's a dual plane manifold can I lean out the rich side by putting a smaller jet on that side of the carb? Any other suggestions why its doing that and how to fix it?
Old Jan 25, 2010 | 08:27 AM
urban_cowboy's Avatar
urban_cowboy
Interesting. I have the same issue but just though I had something screwy going on. I have a similar issue at WOT only where the driver side is leaner than the passenger side 14:1 vs 12.5:1. At crusie, idle, and partial throttle (running on the primaries) the AFR is balanced.
The short answer is no. With a dual plan the runners split with some going left and some going right. You can stager left and right with a single plane somewhat, but it is not really viable to do it with a dual plane.
I have considered sending my Air Gap to Dr. J's http://www.j-performance.com/index.p...d=16&Itemid=30 to see if they can even it out. I read an interesting article on them and intake port work.
I suspect my issue might be a leak somewhere in the driver side either header, head, or intake, but since it only does it during WOT, it is very hard to diagnose.
Jb145700
Aug 21, 2022 06:37 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Dathan
Oct 5, 2015 05:52 AM
firecoyote
Sep 27, 2015 02:37 PM
stangin1996gt
Sep 21, 2015 11:01 AM
