Installing a new antenna
Old Feb 11, 2010 | 08:55 PM
tx65coupe's Avatar
tx65coupe
The antenna shouldn't be very hard to do just have patience. You shouldn't have to remove anything except for the antenna itself. Make sure that the antenna cable is not going to interferre with the heater box.
Old Feb 11, 2010 | 10:25 PM
TheMarco's Avatar
TheMarco
I got the Scott Drake repro antenna so I assume that's as close to 'stock' as it gets
Old Feb 11, 2010 | 11:32 PM
BigIron22's Avatar
BigIron22
to aid in the install. if you tie a string to the old antenna wire before you remove it you can then tie the string to the new antenna wire to help guide it back through to the passenger compartment.
Old Feb 11, 2010 | 11:53 PM
nba1341's Avatar
nba1341
yes! do this
Old Feb 15, 2010 | 05:57 PM
TheMarco's Avatar
TheMarco
Oh well no luck. The old Antenna won't come off. Looks like the screw thread is stuck, it won't twist. I don't have the tools to 'brute force' it off without damaging my hood so I guess I'll have to go somewhere to have it done for me. *sigh*
Old Oct 16, 2021 | 12:54 PM
speechman's Avatar
speechman
Default No hole for antenna
I just became an owner of a 1968 Mustang coupe with no hole for an antenna. I'm assuming a previous owner installed a new fender and didn't drill a hole for an antenna. My question is - do I need to figure out how to get a new hole drilled where an antenna should go or is there a sound system today that may not require an antenna?
Old Oct 17, 2021 | 06:14 AM
2+2GT's Avatar
2+2GT
Well, you can use the antenna template, of course. Foolish of the PO to have no antenna, cutting the hole after painting is inherently more risky the before painting. A small hole saw, then a notch filed with a small round file will do. Tape the spot for safety before cutting. I like to degrade the tape adhesive by sticking it on something first, even your trousers will do. The only hard part is fishing the antenna cable through the fender AND through the side of the cowl. A coat hanger wire can help with that.
Of course, any radio unit that has tape player, disc or even mp3 capability will work without an antenna, but sooner or later you'll want to operate the radio, too.
Old Oct 17, 2021 | 09:29 AM
speechman's Avatar
speechman
Default Thanks 2+2GT regarding antenna
Hard to understand why the antenna would not be reinstalled by whomever replaced the previous fender. Since I haven't cut through painted metal, I'm not sure what the small hole saw would be. I'll have to do some investigating on that. Then I'm assuming it will take a drill to drill through the fender and side of the cowl to run the cable through.
Old Oct 18, 2021 | 05:54 AM
2+2GT's Avatar
2+2GT
The hole is detailed on the template. No drilling needed in the side cowl unless that was replaced and not drilled.
Be careful with this, I'm pretty sure it's the 65-66 template.
mtgldr
Feb 3, 2024 09:00 PM
movielover40
Sep 15, 2015 10:37 AM
Sep 10, 2015 08:39 PM
cbird1177711
Sep 3, 2015 08:43 PM
