289 Oil/Coolant pools.
Old Feb 17, 2010 | 06:59 PM
AlexZi's Avatar
AlexZi
Default 289 Oil/Coolant pools.
Hey. I am getting pools of oil and coolant mixture in crevices towards the front of the engine below the distributor and intake manifold. Ive been getting them for a little while now. If I mop them up, they are usually back fairly quickly. Im putting a picture here with arrows to where the buildups of oil/coolant are. The pic isnt my engine, its just for reference. (Dont have a camera right now to take actual pics.) I was just wondering what could be causing this, and where the leak might be coming from.
Thanks.
Old Feb 17, 2010 | 07:12 PM
nba1341's Avatar
nba1341
Is this area I marked in red done with Black RTV or cork gaskets?
Old Feb 17, 2010 | 07:32 PM
AlexZi's Avatar
AlexZi
Its hard to tell since theres alot of gunk and **** up in there, but Im going to guess its done in cork. I have never replaced that gasket, but I do know there were cork gaskets on my valve covers when I redid those, so chances are the PO used cork everywhere. You can tell that some sort of sealant was used, since some of it is sticking out of the cracks. Willing to bet its cork.
Old Feb 20, 2010 | 01:52 PM
AlexZi's Avatar
AlexZi
Bump?
Old Feb 20, 2010 | 04:05 PM
rtintwo's Avatar
rtintwo
That area is the timing chain cover. It can be coming from 3 possible areas. Intake manifold gasket, head gasket or waterpump. All 3 could be sources for the coolant but only the heads and the intake for the oil.
Take a close look above the pools for any leaks running down. Wipe the pools and above them clean and take it for a quick spin around the block and take another close look to see where it is starting to leak from again.
I would say that what you will most likely find is a very common ford intake manifold leak.
Old Feb 20, 2010 | 04:18 PM
jonward786's Avatar
jonward786
when i had coolant in those spots it was from leaking coolant hoses, the clamps were not tight enough
Old Feb 20, 2010 | 04:56 PM
ic237's Avatar
ic237
I also had coolant there. It was from a damaged timing cover. The timing cover was badly eroded in the coolant passages.
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
ding56
Aug 14, 2015 02:40 AM
