New Door Skin
Old Feb 24, 2010 | 08:33 AM
KoolAidMan888's Avatar
KoolAidMan888
Lightbulb New Door Skin
Quick question. When i put the new skin on and weld should i drill a small hole to weld it on or just weld on the edge. i no need to just tac weld not weld the whole skin on
Old Feb 24, 2010 | 09:02 AM
2+2GT's Avatar
2+2GT
Unless you are trying for the "show correct" look, you don't need the holes. Just tack every couple of inches.
Old Feb 24, 2010 | 10:31 AM
chris66dad's Avatar
chris66dad
I drilled holes into the lip that folds over and then plug welded them with the MIG. I spaced the holes about 6 inches apart.
Pictures of the door skin install: http://chris66dad.tripod.com/id19.html
Old Feb 24, 2010 | 10:51 AM
64.5stanger's Avatar
64.5stanger
+1 for plug welding as chrisdad said, if you are going to do the work take a extra 1/2hr and drill the holes. IMO
Old Feb 24, 2010 | 06:07 PM
KoolAidMan888
i drilled the wholes and was about to put the skin on.. For some reason i just wanted to see how hard the little bit of bondo i used to fill in a little spotty rust holes.. all of it was good but the one peice that didnt have alot smushed through. i primmerd the door and it looked good. The bondo fell out. =( none the less i sanded it down and put a peice of duct tape behind the whole and smushed alot through and now its all better again Woo hooo putting the skin on friday.. Thanks guys
Old Feb 24, 2010 | 08:42 PM
64.5stanger
bondo n rust, this will likely fall apart in the years to come.
Old Feb 24, 2010 | 09:23 PM
JMD's Avatar
JMD
we need a picture of that.....
Old Feb 25, 2010 | 01:14 AM
67t5ponycoupe's Avatar
67t5ponycoupe
If you have to do that to rust such as on a small spot on the inside of a door you should sandblast just that area inside and out and use duraglass not bondo. Make sure it has a good primer on it after you are done.
Old Feb 25, 2010 | 12:59 PM
KoolAidMan888
I have the Duo point rust fighting primer over it and then sealed. it i would have cut the rust out then put a new peice in but its rusted in a groove so i just bondoed it.. Worst case in a couple years ill just get a new door for it. or just let it go its on the inside of the car and you cant see it unless you lay down on the ground. i plan on making the car a daily driver and show it in small shows nothing big. Ill put some picks up tmrw or sat.. Thanks
Old Feb 26, 2010 | 08:41 AM
JMD's Avatar
JMD
There are a lot of us here who get stuck on "doing things right", but fact is sometimes budget and/or time constraints mean we do what we can, (so long as we are not talking a safety issue).
In my youth I had glassed over some holes in the bottom of doors, last time I looked at this truck a few years ago, the patches were still perfect. At this point the truck has been parked for 10 years after being used for 13 with the patches. The patches have proved good enough until I get back to working on the truck again.
