Clutch help
Old Feb 24, 2010 | 09:30 PM
JMD's Avatar
JMD
So long as it fits in the housing it should work fine, it won't hurt the car. If it worked before it should work now, assuming everything else is the same.
If you knew the application the clutch came from it would open up the possibilities on the diaphragm clutch.
Do a search on the part number of the pressure plate to try and find the application and then go from there.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
