5.0 engine and trans question
Old Mar 1, 2010 | 09:27 PM
lalojamesliz's Avatar
lalojamesliz
Default 5.0 engine and trans question
i found a 5.0 from a 92 thunderbird that still is complete with the EFI minus the engine harness and a 5 speed trans from a 1983 5.0.... will these fit in my 1969 mustang coupe? these are in somebody's project car that they gave up on and are selling the car and engine/trans for $400 so i need to decide soon on to buy this or not. please help guys
Old Mar 1, 2010 | 09:55 PM
boogerschnot's Avatar
boogerschnot
buy it. You could allways keep the trans and sell the motor again for the same price or a little less. Thats what I did. 93 5.0 and aod for $300. kept the aod, starter, and alternator and sold the engine for $350
Old Mar 1, 2010 | 09:58 PM
lalojamesliz
so for the $400 i get a 1961 el ranchero in ok condition and the engine and trans....
Old Mar 1, 2010 | 10:00 PM
lalojamesliz
but will these two fit into my 69?
Old Mar 2, 2010 | 07:48 AM
MustangBradley's Avatar
MustangBradley
The 5.0 will fit in your 69. The 69 has more space than my 65 and I fit a 95GT 5.0 in with a 1/2 inch to spare.
http://mustangefiswap.blogspot.com/
Old Mar 2, 2010 | 08:48 AM
2+2GT's Avatar
2+2GT
i found a 5.0 from a 92 thunderbird… …and a 5 speed trans from a 1983 5.0.... will these fit in my 1969 mustang coupe?
With the appropriate bellhousing and trans crossmember, this combo will fit your 69 as though it were original equipment.
Old Mar 2, 2010 | 09:56 AM
mustang anthony's Avatar
mustang anthony
This is a great swap for a Mustang. I noticed you said it was missing the harness.
Whatever you do don't swap to a carb. The EFI motors are to high compression and the cam profiles are all wrong for carbs. You will wind up setting your timing to low to keep from detonating and have no low end power, or running premium fuel all the time. I have seen this done several times and it just doesn't work out right. Stick with the EFI setup. The ECU can set the timing and adjust the fuel to get the most out of that camshaft and heads. Its not that hard and you will be glad you did.
Old Mar 2, 2010 | 10:54 AM
OCHOHILL's Avatar
OCHOHILL
I swapped a 91 gt mustang in and went with a carb and I haven't had any problems to date. Although, I will admit I am running a highly modified carb that is more than likely a little rich. I always run premium or midgrade. I have 1000 miles and it works well for me.
Old Mar 3, 2010 | 08:51 AM
lalojamesliz
thank you for all the great advise guys ill keep you updated on what i do
Old Mar 4, 2010 | 09:16 AM
mustang anthony
That's my point. You can run EFI without running rich or running premium all the time. If your goal is a daily driver that's easy to live with EFI is the way to go.
Cannibal_carnies
Mar 2, 2023 06:17 PM
djbigskrilla
Sep 20, 2022 01:04 AM
Stilz
Aug 18, 2015 09:40 AM
05slpGT
Aug 12, 2015 02:32 PM
$A_Money$81
Aug 11, 2015 01:30 PM
