i hate sap....ideas?
Old Mar 22, 2010 | 01:02 AM
photocliff's Avatar
photocliff
Ditto on the WD-40. It's a gentle way.
Old Mar 22, 2010 | 02:19 PM
Nabster's Avatar
Nabster
Originally Posted by longlive289s
as i said....the sap remover spray/gel doesnt do a damn thing
You say that, but which brand(s) did you try? I've always had good luck with Stoner Tarminator- spray it on and let it sit a little while it even takes off baked on yellow/brown pine tree sap.
Old Mar 22, 2010 | 02:35 PM
THUMPIN455's Avatar
THUMPIN455
Im not the guy to ask, I tend to bust out the DA and 80 grit before thinking about it... Hot soapy water, WD40 or some alky, and then a clay bar. Polish it up good after. A detail shop should be able to handle it quick and painlessly.
Old Mar 22, 2010 | 05:47 PM
longlive289s's Avatar
longlive289s
thanks guys. ive tried 2 or 3 different sprays but havnt tried wd 40 at all. think ill just go at it with that and some alcohol. worst case ill try guns idea. thanks again. summer is comin....gotta start breaking the horses out. btw actually that cover has been one of the best i've gotten. not cheap material at all either
edit: just been going at it with wd40. works perfectly with a little elbow grease. thanks guys!
Old Mar 23, 2010 | 04:33 AM
tx65coupe's Avatar
tx65coupe
I have always heard that WD works good for that type of stuff. Thats good to know that it worked out for you. Don't forget to wax the car again.
Old Mar 23, 2010 | 08:59 AM
stephen.osborne1's Avatar
stephen.osborne1
That's good news... I have been worried about my pine trees in my driveway (as well as the cherry trees) "spitting" all over my car (and the new truck) here in the near future. I knew WD40 worked well on chrome and glass but wasn't sure if it was safe on painted surfaces.
Old Mar 23, 2010 | 04:33 PM
DRAGUL's Avatar
DRAGUL
Yeah try wd-40. I use it to get the sap off and it works great at getting off road tar too. Has kerosene in it so works good as a solvent. Never had a problem putting it on a painted surface. You will be looking at a new paint job using a wire brush. If still no results contact a detail shop see if they can give you any guidance on a product or see if they can remove.
Old Mar 23, 2010 | 05:44 PM
groho's Avatar
groho
WD40 works great on anything that's sticky!!!!!
Old Mar 23, 2010 | 06:29 PM
Razrbak's Avatar
Razrbak
I'd try a clay bar from Mothers or Meguiars.
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
Ipaman
Sep 22, 2015 07:01 AM
ccdguy
Sep 19, 2015 05:20 PM
BrantleyS550
Sep 14, 2015 04:18 PM
jaiidutch
Sep 14, 2015 10:29 AM
