i hate sap....ideas?
Old Mar 21, 2010 | 04:59 PM
longlive289s's Avatar
longlive289s
Default i hate sap....ideas?
so awhile back when i was gone i mentioned to my dad to take the mustang out and keep the fluids runnin thru her and not let her sit for months on end. he did this but forgot to put the tarp back on her when he was done.....thus this happens.
i got 3 brushes, nylon, brass, and stainless steel. nylon was to soft. brass seems to work if i scratch softly but still leaves a trace amount left. dont wanna use the stainless steel one since it will probably scratch the paint.
i've tried a bug, tar, and sap remover spray but that does squat. Any ideas short of hunching over the car for hours next weekend? other idea was swallow my pride and do a quick $400 maaco paint job (god help me). really really really dont wanna do that but worst case scenario.....
thanks in advance
Old Mar 21, 2010 | 05:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
im gonna go with tree sap remover.....
also a razor blade will work but if youve never used it to remove pinstripes etc i dont suggest it
Old Mar 21, 2010 | 05:41 PM
longlive289s
as i said....the sap remover spray/gel doesnt do a damn thing
Old Mar 21, 2010 | 05:45 PM
JMD's Avatar
JMD
Will rubbing compound and/or polish help?
Temperature may help you out some, try when it is warm and try when it is cold.
Maybe a "like solvent" will soften it up, like maple syrup? Just a guess....
Old Mar 21, 2010 | 06:14 PM
Gun Jam's Avatar
Gun Jam
I would try lighter fluid to attempt to soften or dissolve the sap.
If that doesnt work
Buy a wool polishing wheel with the velcro base to attach to a good drill. Get a medium cut compound and use highest speed on the drill use medium pressure and work a small section at a time. The heat / compound should remove the sap, scratches, and some paint.
Go over the section with a glaze like meguiars # 7 with a foam pad that will attach to the same base as the wool pad.
Then go over it with a wax.
Make sure the paint is as clean (dust dirt free) before doing any buffing / cutting.
-Gun
Old Mar 21, 2010 | 07:42 PM
cmanf's Avatar
cmanf
had that problem from a pine tree in my drive way a few years back straight rubbing alcohol and a rag got it off my truck with out any damage . Just wax it when your done it does strip it off.
Old Mar 21, 2010 | 08:02 PM
1slow67's Avatar
1slow67
ROTM Moderator
What about Goo Gone?
Old Mar 21, 2010 | 09:40 PM
hiboostwoody's Avatar
hiboostwoody
WD-40 usually works too. Just spray it on, let it sit a little bit and polish it off. Might have to do it a few times but it will work. Works great for removing sticker and decal residue too.
Old Mar 21, 2010 | 09:59 PM
plainsman1876's Avatar
plainsman1876
That suck bud I'm sorry,
Old Mar 22, 2010 | 12:49 AM
tx65coupe's Avatar
tx65coupe
That sucks. I can't believe its that bad. I would think that most of that would come off with just some good car soap and a soft sponge.
By the way don't cover your car with that cheapo blue tarp. They scratch the paint and they don't breathe at all so they hold in moisture. You can get a car cover for not much money.
