engine bolt question
Old Mar 26, 2010 | 06:27 PM
polo708's Avatar
polo708
Default engine bolt question
This is probably the dumbest question ever asked so...
I bought my engine stand and finally unwrapped my motor. What bolts (size & length) do I need to mount this motor to the stand? Are they the same bolts I will be using to mount the bellhousing or should I buy different bolts for it while its in the engine stand? Is this a Home Depot bolt pick up or my local race shop?
Its a ford small block (347 stroker)
Old Mar 26, 2010 | 07:28 PM
Bubba 95SN's Avatar
Bubba 95SN
7/16" x 14 threads per inch x 3" is what my stand uses. Bolt length my differ, measure for proper length. Get a couple flat washers.
Old Mar 26, 2010 | 07:39 PM
ALMOST STOCK's Avatar
ALMOST STOCK
SAE 7/16-14 for 302/351W
Mod motors are 10 mm if I am not mistaken.
Length would depend on the the thickness of material use on "your" engine stand + the original length.
Old Mar 26, 2010 | 07:48 PM
polo708's Avatar
polo708
Thanks, can I get bolts from Home Depot or do I need some from a race/car shop?
Old Mar 26, 2010 | 09:23 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
what year car is this going in???
Old Mar 26, 2010 | 10:05 PM
ALMOST STOCK
Home Depot, Lowe's....... I bought mine at a local hardware store.
Old Mar 27, 2010 | 12:45 AM
Tomahawk715's Avatar
Tomahawk715
Do yourself a favor and make sure the bolts and washers are grade 8----dont save two bucks and end up with your motor on the floor.
I'd go where Almost Stock did--a good local hardware store. TSC Lowes HD all seem to carry the China hardware which I've seen snap in 4wd applications--IE I dont trust their grade rating.
Old Mar 27, 2010 | 09:36 AM
polo708's Avatar
polo708
Thanks alot guys
its going in my 67 Coupe
Old Mar 27, 2010 | 10:17 AM
stephen.osborne1's Avatar
stephen.osborne1
ditto on grade 8... I learned the hard way in high school... putting a new 400 in my 77 f-150 using an old Ford 2000 Industrial bucket loader as a lift... Raised the engine to clear the front grill and the bolts in the intake snapped (grade 5). Luckily I just crushed the oil pan and pickup. Felt like an @$$ though.
msavoia23
12
Jul 7, 2018 12:08 PM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
