Over heating
Old Mar 28, 2010 | 08:17 AM
mortman's Avatar
mortman
Default Over heating
Car was over heating at Idol, so i replaced the water pump, thermostat, got the radiator cleaned out Buttoned her up and no over hearing issues, found a frew leaks, disassembled/resembled. No leaks or heating problem. A few weeks later radiator begins to leak again. I replace the radiator yesterday with a 3 row alum one, idol for 20 min and it boiled over, gauge cluster is not in the car so a don't know what if it read, but i assume that the boiling over is no doubt over heated. The heater core was replaced 3 years ago.
should i just pull the thermostat and forget about it?
also what is the best way to clean out the water jackets (flush the system) with the motor still in the car?
BTW Stock 289, no fan shroud. I don't drive the car, she is still under construction just fire her up once in a while to get the juices flowing
Old Mar 28, 2010 | 12:58 PM
stephen.osborne1's Avatar
stephen.osborne1
Have you had the heads off recently? I'm thinking head gasket(s) installed backwards. Also, could just be rust/debris clogging the radiator... you said you had it cleaned out but what about the rest of the cooling system? the block tends to accumulate a bunch of crap, especially when it is not run regularly. Have you checked to see if you have a properly diluted antifreeze mix? too much water will cause more rusting in the system.
I'd take it to a shop that can truly flush the whole cooling system, then replace the thermostat again for good measure (they always go bad).
Old Mar 28, 2010 | 03:44 PM
ic237's Avatar
ic237
Did you get the cap with the radiator or did use reuse your old one?
Be a little careful, I have had 3 aftermarket alluminum radiators and none had std rad caps. The only rad that worked was the one that came with it own cap.
Old Mar 28, 2010 | 05:38 PM
2+2GT's Avatar
2+2GT
You watch too much TV.
, so i replaced the water pump, thermostat, got the radiator cleaned out Buttoned her up and no over hearing issues, found a few leaks, disassembled/resembled. No leaks or heating problem. A few weeks later radiator begins to leak again.
Old radiator? It was it's time.
I replace the radiator yesterday with a 3 row alum one, idol [there's that TV show again] for 20 min and it boiled over
The coolant level in the radiator should be filled to 1" below the ring under the cap. Any more full than that, and normal expansion will give you fluid all over the place.
Bad idea. Removing the thermostat just means it will never be at the right temperature.
Use a reverse flush through the hose connection on the top of the intake manifold.
If the engine has been bored oversize, you'll need a 3-row radiator, shroud, and 6-blade fan, preferably a thermal clutch fan, and certainly not a 'flex' fan.
Old Mar 28, 2010 | 06:55 PM
67mustang302's Avatar
67mustang302
If it only over heats at idle it's usually a fan/shroud issue.
Old Mar 30, 2010 | 11:18 PM
mortman's Avatar
mortman
If i would have reached around and pulled my head out of my duffel bag i would have realized i had the thermostat in backwards
Old Mar 31, 2010 | 01:05 AM
67mustang302
lulz
It happens. At least it wasn't an actual problem that required money to fix.
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
