Welding ?
Old Apr 1, 2010 | 02:57 PM
  #31
67mustang302's Avatar
67mustang302
Most of the welders now if you open the panel where the wire spool goes, has machine settings for the gas and metal thickness listed.
Old Apr 1, 2010 | 09:45 PM
  #32
Tomahawk715's Avatar
Tomahawk715
Talking
http://www.northerntool.com/shop/too...0402_200310402
Buy it----believe TSC carries it as well.
Old Apr 2, 2010 | 01:06 AM
  #33
71Mach14spd's Avatar
71Mach14spd
Originally Posted by jcoby
if you have oxygen in your gas without carbon, you've got the wrong stuff.
I've always used 75/25 argon/oxy on sheet metal, that's what ive always been told to use. What am i supposed to be using?
Old Apr 2, 2010 | 01:28 AM
  #34
71Mach14spd
Sorry i had my brother typing those and hes an idiot sometimes. He was supposed to be saying co2 not oxygen.
Old May 2, 2010 | 09:30 PM
  #35
chiefymcpots's Avatar
chiefymcpots
its very plain and simple use the .035 or even .o45 bare wire, but it will need gas, other wise you can use flux core wire but the thicker wire you use the less heat will stay in the part , because the wire wire will use most of the arc or heat to melt, therefore no burn through, and use whats called trigger welding on body sheet metal, dont run beads
Old May 2, 2010 | 09:38 PM
  #36
taylorjones's Avatar
taylorjones
please dont use flux core for body work. the only time i used flux core was for welding in the seat platforms but if i had gas available i would have used it like the rest of the body!
drfister
May 3, 2018 10:38 PM
cyclop5
Oct 3, 2015 09:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
