painting engine
Old Mar 30, 2010 | 01:38 PM
Mustanggt9589's Avatar
Mustanggt9589
Default painting engine
I am going to embark on painting my first engine this weekend and was looking for some advice.I have no experience the only thing i know is i have to mask off any hole that lead into the engine as to not get paint in the engine. i need help in the following:
1. I need to know what can't be painted and needs to come off the engine
2. Do i or should I use primer?
3. After power washing and letting dry should i Use some type of paint thinner or grease remover before priming?
4. Any good paint products or techniques anyone has used
I know these might be dumb questions but like I said this is my first time painting and engine so any help is greatly appreciated.
Old Mar 30, 2010 | 02:10 PM
2+2GT's Avatar
2+2GT
Assuming you have a blue 66-73 engine, remove the alternator brackets, PS and AC brackets, and pulleys. Remove the starter, distributor, and fuel pump. Remove the carburetor. Remove the spark plug holes and plug them.
No.
Absolutely. All trace of grease, dirt, and oil must be removed.
Many products will do, even rattle cans, although I prefer quarts sprayed from a gun. POR-15, best know for their rust treatment, has an absolutely excellent line of real engine enamel. Available in pints (enough for one engine) quarts and in engine painting kits, it flows on so smoothly (takes two hours to get tacky) that even if brushed on it flows out without brush marks. Dries slowly, you must wait nearly a week to run the engine, but the excellent appearance and durability are worth the wait.
Old Mar 30, 2010 | 11:43 PM
71Mach14spd's Avatar
71Mach14spd
As previously stated, there can't be any grease or dirt anywhere or the pain won't stick. Don't primer it. Any high temp engine enamel will work just fine, I've had great luck with rattle cans.
Old Mar 31, 2010 | 12:47 AM
nba1341's Avatar
nba1341
A little addition to this thread. After 4 years of engine being painted the paint on the oil pan paint is cracking and can be peeled off. Is there away to prevent this in the future?
Old Mar 31, 2010 | 08:52 PM
jmk3's Avatar
jmk3
I just painted mine, out of the car. after much research I decided to use epoxie primer on the block, one thin coat. I topcoated it with eastwoods 2 part engine paint in ford dark blue. The results are amazing, it looks better than anything detroit put out. You can see yourself in the machined surfaces of the head & block. This would be hard in the car & no rattle cans were used obviously. I bead blasted the aluminum intake & coated it with eastwoods diamond clear coat. It looks twice as good as my 06 GT motor. It was painted by the previous owner with cans & most of it fell off.
Old Mar 31, 2010 | 09:30 PM
JMD's Avatar
JMD
I ALWAYS use 2 part car paint, I have for over 20 years.
It lasts, and lasts, and lasts...
I saved the Chevy for last....
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mustangchef
Sep 4, 2015 08:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
