Hydroboost brakes?
Old Apr 1, 2010 | 12:07 AM
71Mach14spd's Avatar
71Mach14spd
Default Hydroboost brakes?
Due to how radical my cam is im fearful of my power brakes not working. I was told about the hydroboost brakes and was wondering if anyone has used them or knows anything about them. Any info will be great, thanks a lot.
Old Apr 1, 2010 | 08:33 AM
JMD's Avatar
JMD
Hydro-boost was used extensively on GM's larger pick up trucks and some large cars in the late 70s and 80s.
The system uses the power steering pump to power a special booster instead of engine vacuum.
It is a good reliable system with excellent stopping characteristics, IMO the additional hoses can look kind of cumbersome, but would probably look ok in a larger engine compartment like a 71.
If I were you I think I might consider a vac pump instead, it is just simpler.
Old Apr 1, 2010 | 08:43 AM
urban_cowboy's Avatar
urban_cowboy
I took have been considering a hydraulic brake booster. What brands are out there? I am worried that an electric vacuum pump running all the time (manifold vacuum stays below 20" almost all the time) will not last long.
Old Apr 1, 2010 | 11:30 AM
71Mach14spd
The vacuum system was what i was considering first. I do agree about it being easier but i just don't know how reliable it is. Plus how would i hide that ugly vacuum pump so that it couldn't be seen haha.
Old Apr 1, 2010 | 11:33 AM
71Mach14spd
I haven't actually measured the vacuum on the motor yet because i haven't put it in the car im just assuming that im not going to have enough.
Old Apr 1, 2010 | 11:50 AM
urban_cowboy
You need to maintain like 16-18" for vacuum assist brakes to work. I run 10-12" at idle and 15-17" cruising, so it is out for me without a vacuum booster pump which comes on when you vacuum is less than 16", so it would run almost all the time in my setup. I am running a 242 duration roller cam @ .050 and .64 lift in my 383 if that helps you compare.
Old Apr 1, 2010 | 02:34 PM
71Mach14spd
Yeah then there is no way that mine will have enough vacuum haha. My cam has 304 duration and .612 lift. Thanks the info.
Old Apr 1, 2010 | 02:44 PM
urban_cowboy
The 304 duration is going to be advertised duration. What really counts is your duration @ .050 because some cams ramp up faster than others. My advertised duration is 280 but duration at .050 is 242/248. Depending on what your duration is at .050 there may still be hope, but probably not.
Old Apr 1, 2010 | 08:37 PM
andrewmp6's Avatar
andrewmp6
Have you looked at http://www.abspowerbrake.com/ they have a electro booster that will do the same job if not better and looks a lot better.
Old Apr 2, 2010 | 12:59 AM
71Mach14spd
Thanks for the info I will definitely look into that.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
