timming gear drive kit
can anyone that has used a timming gear drive kit post their feedback on the kits? im looking into getting one for my stock 351w, well im getting a mild cam, i like the airgap intake manifold a 600 size carb and headers of course. so if anyone has used them can you tell me if its a good or bad idea to get a kit?
If you are going to run one, DO NOT get one of the cheap ones!!!! I got one off ebay for around 80 bucks, it was new but the material they used wasn't strong enough or the dimensions were off. I ran it for a few months just cruising it till everything was broken in. Well, finally jumped on it an I guess a couple 7K revs was too much. The dual idler brackets had twisted. Thank God nothing happened to the engine..... I now have a Comp Cams one in it and its great.
One of the guys on another forum ran one in his stroker...and it blew up. One of the circlips holding on an idler gear worked loose, which tore everything apart. This was an Edelbrock unit, iirc.
Use a good Cloyes double roller set and you'll be fine.
Figure8allday
Aug 22, 2015 11:11 AM
I love this forum!
