It Happened!
Old Jan 26, 2012 | 01:14 PM
  #391
Jonk67's Avatar
Jonk67
Any special reason for the intake swap? the weiand you have and the summit are both idle -6k RPM? If it's height that's worring you is the summit any shorter? I use a 1/2" phenolic spacer as that's all i could fit.
I'm pretty sure roller blocks all top out around 5K rpm so those intakes will work better with that than a highrise designed for say 6800 RPM like my weiand stealth.
I wouldn't change carbs unless you're having issues, rejetting it may make a big differnce if you are having issues. If you were way over carbed like 750cfm I'd say yes or if you just want to try a different carb.
Jon
Old Jan 26, 2012 | 02:19 PM
  #392
1slow67's Avatar
1slow67
ROTM Moderator
The intake I have is cracked in a couple areas where plugs are in the water crossovers. And they are leaking. I'm going to ask my grandfather if they can be welded.
Old Jan 28, 2012 | 05:08 PM
  #393
1slow67's Avatar
1slow67
ROTM Moderator
My newest appearance mod, I love the look. My dad really likes the look as well.
Old Feb 1, 2012 | 07:52 PM
  #394
1slow67's Avatar
1slow67
ROTM Moderator
Gauge pod, oil pressure gauge, and air/fuel gauge on their way.
Old Feb 2, 2012 | 07:41 AM
  #395
Jonk67's Avatar
Jonk67
Stripes look better at an angle. I like more gauges, I had a pair of SW GreenLine oil/water gauges restored to put in a console eventually like the GT350's. Just ordered a vacuum gauge and trans temp gauge for my AOD to keep an eye on it. Ordered yesterday and will be here today, way to go summit.
Jon
Old Feb 2, 2012 | 12:08 PM
  #396
1slow67's Avatar
1slow67
ROTM Moderator
Yeah I don't trust the original oil pressure gauge, not accurate enough. Want to keep an eye on my air/fuel as well. I'm eventually going to replace all of my stock gauges.
Old Feb 3, 2012 | 09:13 PM
  #397
1slow67's Avatar
1slow67
ROTM Moderator
Just waiting on my gauge pod now.
Old Feb 4, 2012 | 02:54 PM
  #398
jojobanks's Avatar
jojobanks
the oil pressure gauge is cool, but the narrowband a/f gauge is just going to give you a pretty light show. You need a wideband to actually monitor your a/f ratio.
Old Feb 4, 2012 | 03:09 PM
  #399
1slow67's Avatar
1slow67
ROTM Moderator
Yeah I'm not wasting $250+ on a gauge, I have better things for that money.
Old Feb 4, 2012 | 06:25 PM
  #400
1slow67's Avatar
1slow67
ROTM Moderator
Soon I will be continuing to fix it up. I have decided to enter my car in the 7th annual Good Guys show in Nashville this upcoming May.
http://www.good-guys.com/events/even...eventid=12-607
Last year there was a major lack of mustangs when me and my dad went and walked around. Out of the 1000+ cars there I saw maybe 6 mustangs, whole lot of camaros though.
So far I have a good list of things to do: painting door jams, painting trunk lid, painting trunk, fixing the paint problems, getting it cut and buffed, finish interior, possibly redo the engine compartment, and undercoat the underside of the mustang.
And for my birthday I am hoping to go and try and get my new exhaust installed.
