shifter boot
Old Jun 6, 2010 | 06:55 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Back on the boot issue...
I got the old one off as per everyone's advice. I walked it over the t-handle and applied extra violence to get it over the gear ****.
now i cant get the replacement back on. it wont even go over the ****. There must be a way to do this! Its a standard replacement from one of the vendors.
btw Kalli. the box end isnt an option. It goes to a kind of T where it bolts to the selectors which is bigger than the lockout T.
anyone?
Old Jun 6, 2010 | 08:17 PM
1969boss302's Avatar
1969boss302
Remove the **** and you should be good to go. The boot will stretch over the t-lock.
Old Jun 6, 2010 | 09:24 PM
Aussie66Fastback
ok, how do you remove the ****???
it doesnt seem to want to twist off and I was reluctant to force it
Old Jun 7, 2010 | 03:02 AM
tx65coupe's Avatar
tx65coupe
It should twist off. There should also be a nut on the bottom of it. It allows you to get it straight. Try backing the nut off, which would actually be rotating it so it goes farther on the shifter.
Old Jun 7, 2010 | 04:12 AM
Aussie66Fastback
thanks Tx
it doesnt seem to have any nut
the black ball is sitting on a chrome half ball shaped bezel then onto the stalk of the shifter.
there seems to be 2 small holes thru the bezel (on the underside). I thought these might have had grub screws or similar but they'd be really small if thats what they are.
i'm wondering if PO (who is known to have done dumb things to this car) maybe glued it on?
Old Jun 8, 2010 | 02:37 AM
tx65coupe's Avatar
tx65coupe
Is the shifter ball a factory type one or a custom one? If its a custom one, maybe it doesn't fit right and is crossthreaded.
Old Jun 8, 2010 | 07:08 AM
Aussie66Fastback
its the factory style...couldnt say if its original but had always assumed so.
the car is back with the engine builder for tuning so i will have another look when I go down there in a couple of days.
Old Jun 8, 2010 | 11:35 AM
2+2GT's Avatar
2+2GT
The chrome thing is the locknut.
Old Jun 8, 2010 | 06:41 PM
Aussie66Fastback
thanks!
so how do i undo it without damaging it?
are the holes in the locknut for some kind of special tool?
Old Jun 8, 2010 | 07:03 PM
2+2GT's Avatar
2+2GT
Usually I just get a grip on the shaft with my hand against the locknut, and unscrew the **** from the top. However, a snap ring plier works well to hold the nut while removing the ****.
