headliner
Old May 2, 2010 | 09:08 PM
6mustang6's Avatar
6mustang6
Default headliner
Well, my 66 has been sitting in the garage for a few years and i started getting her back out. I noticed my headliner has split in the middle seam and is sagging down. Is there any way to repair it on the car, or does it just need to be replaced? Im sure it does, but is it totally true that you have to have the front and rear windshields out to replace it?
Old May 2, 2010 | 09:51 PM
2+2GT's Avatar
2+2GT
Yeah, it's true. Any trick that tries to avoid removing the glass just doesn't hold up. Here you can see a 68 GT350 that already has the headliner installed. While being detailed, the headliner has been protected from dust, overspray, etc.
Old May 3, 2010 | 06:57 AM
6mustang6's Avatar
6mustang6
wow that just freaking sucks....
Old May 3, 2010 | 08:08 AM
tcrote5516's Avatar
tcrote5516
Trust me, the hard part is NOT removing the front and rear windows....its the headliner. The windows seem like a piece of cake after pulling, yanking, trimming the headliner to remove all the wrinkles and get it tight.
Old May 3, 2010 | 06:09 PM
oldrock's Avatar
oldrock
in the spirit of full disclosure, you can in fact install a headliner without removing the glass. It isn't easy but it can be done. I did it to my 69 coupe and although it didn't turn out perfect but not bad and way better than the crappy headliner that was in it. So removing glass is best and easiest but it can be done without it if you aren't demanding perfect results and just don't want to have to remove the glass.
Old May 16, 2010 | 12:58 AM
az1966's Avatar
az1966
did my headliner with the glass in also ,,,,used a couple dull putty kinfe's 1) approx 1 inch wide,,the other approx 3 " wide and a butter knife,, ( used to tuc the headliner in between the window seals and frame ) headliner was 25 bucks,,contact cemet at hardware store approx 5 bucks for a quart,, package of throw away brushes and a drop cloth to protech the front seats/carpet. had new insulation for roof at the ready.... pulled the rods out in sequence and put back in the same way,,bought new restraining wires for the rear rod to cover the bases
Old May 16, 2010 | 01:02 AM
wumarshall82's Avatar
wumarshall82
the only way to get it right would be to remove the glass. you should be able to get the front and back glass removed and installed for around $150 or less
Old May 16, 2010 | 01:23 AM
irish350's Avatar
irish350
wow, damn.. didnt realize you had to do that. How hard is removing factory glass? (like how sure do i need to be that the shops competent.. i dont wanna ruin it myself)
Old May 16, 2010 | 06:06 AM
Bitter's Avatar
Bitter
While on this subject... I bought my '68 coupe without a headliner or rods. I have new rods/liner and will be attempting to replace it soon (with the glass out). Does anyone know the order of the colored rods?
Old May 16, 2010 | 08:38 AM
2+2GT's Avatar
2+2GT
The 69-73 does not require removing the front glass.
For the additional work of removing the glass, you get excellent results, instead of just "better than before".
Roger Mabry
Jun 15, 2016 08:27 AM
MonsterBilly
Sep 19, 2015 08:50 PM
yurizx6r
Aug 24, 2015 05:48 AM
mrsoup
Sep 17, 2004 04:05 AM
uppy
Nov 3, 2003 07:48 PM
