Speedo cable issue
Old May 10, 2010 | 01:26 PM
paddy187's Avatar
paddy187
Default Speedo cable issue
My speed at low speeds is bounce i.e. flucturates wildly does that mean the gear is buggered or what?
Old May 10, 2010 | 01:45 PM
kalli's Avatar
kalli
greetings European ... ;-)
had the same with mine (i have the long type speedo) and it's either
- not lubricated
- wrong cable routing (to harsh a bend)
- wrecked speedo cable
check the routing first, if that's ok unplug it from speedo, pour some lubricant in there. i just used spray oil in there and shove it back in. if all that doesn't help try a new cable and route it as 'flat' as possible
Old May 10, 2010 | 02:07 PM
2+2GT's Avatar
2+2GT
Use some gun oil on the speedometer shaft, it's non-gumming. Then look at the cable.
Old May 10, 2010 | 02:09 PM
paddy187's Avatar
paddy187
Hey kalli,
Cheers, I hope it the lube, it only started doing it after I replace the turn signal lamp, so I will take out the cluster and re-assembly with extra lube!
Old May 10, 2010 | 02:26 PM
67mustang302's Avatar
67mustang302
It could also be the gearset inside the speedo itself in the dash, which you'd have to pull to inspect.
Old May 10, 2010 | 03:32 PM
paddy187's Avatar
paddy187
Think I got it, getting dark here and have no dash lights so will see 2mrrw in the light
Old May 10, 2010 | 07:23 PM
djsprinklesnjo's Avatar
djsprinklesnjo
yea same thing i was going to mention. spray some wd40 or any other lube down into the shaft and it will spin freely. but after what you said about doing the turn signals and now it bounces around indicated either you put it back incorrectly or maybe its not "seated" properly in the back of the dash. but spraying some oil on it also will only help.
Old May 11, 2010 | 12:38 AM
synthartist69's Avatar
synthartist69
From experience. I replaced the cable, no improvement, I replaced the speedometer, no improvement. I noticed wear on the speedo gear in the transmission so replaced it, problem solved. However, it bounces around at high speed now!
Old May 11, 2010 | 05:06 AM
kalli's Avatar
kalli
the gun-oil would be great for it, but never seen any in Ireland. In Germany I always had some Ballistol, which might be possible to get in Netherlands as well.
Old May 11, 2010 | 08:28 AM
JMD's Avatar
JMD
No gun oil?
That is ridiculous!
