Oil pressure sensor
Old May 30, 2010 | 07:41 PM
_Remi's Avatar
_Remi
Default Oil pressure sensor
Hi friends,
My oil pressure sensor is dead, what is the exact part I need to get? It's a 67 with a 289.
Thanks!
Old May 30, 2010 | 07:55 PM
nassaubayman's Avatar
nassaubayman
Oil Pressure Sending Unit
http://www.mustangsunlimited.com/ite...?T1=SW1547B+01
Old May 30, 2010 | 07:56 PM
mortman's Avatar
mortman
any parts house will have them for 15 bucks
Old May 30, 2010 | 07:59 PM
_Remi's Avatar
_Remi
Love that forum, thanks guy.
Old May 31, 2010 | 03:48 AM
kalli's Avatar
kalli
Hi Remi,
you can very easily check if it's the sensor:
switch ignition on and disconnect the cable at sensor (and make sure it doesn't touch anywhere), gauge should go to one side.
Then touch the cable from sensor directly to ground (header, block, etc) the gauge should go the opposite side.
the way the sensor works is just with the presure increasing it reduces the resistance to ground. huge pressure, low resistance and the gauge peeks. if you attach it directly to ground the gauge goes as far as it will ever do. hope it makes sense
Old May 31, 2010 | 08:03 PM
_Remi's Avatar
_Remi
Thanks Kalli, it does exactly that!
Old Jun 1, 2010 | 03:04 AM
kalli's Avatar
kalli
then it's 100% sensor faulty, or you have no oil in there ;-)
Old Jun 2, 2010 | 08:03 AM
nassaubayman
Originally Posted by kalli
Hi Remi,
Can the temp gauge be tested the same way?
Old Jun 2, 2010 | 11:02 AM
2+2GT's Avatar
2+2GT
Yes .
Old Jun 2, 2010 | 11:17 AM
kalli's Avatar
kalli
yep. the very same way. same goes for fuel sender
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
