ballast resistor
Old Jun 20, 2010 | 11:09 AM
Starfury's Avatar
Starfury
Just go to a good parts store and tell them what you're doing. They'll find the right resistor for you, and will probably even have it on the shelf.
Old Jun 20, 2010 | 12:43 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I agree, get the right ballast resistor at the parts store. Don't try to fix it at Radio Shack. I don't don't know what the Ohm value of the ballast resistor but it is the Watts and the heat dissipation that will kick your butt. Ballast resistors are readily availible I have 3 in my tool box.
Old Jun 22, 2010 | 12:47 AM
groho's Avatar
groho
a quick check on web show about .8 ohms will take you down to 7 V. Any decent parts store or performance shop should have them for under $15.
Old Jun 22, 2010 | 01:37 PM
mstngsule68's Avatar
mstngsule68
thank you! exactly what i needed to know
Old Jun 23, 2010 | 08:05 AM
kalli's Avatar
kalli
well ... have you even measured the voltage at coil?
if noone did any modifications you should be there at 7V-8.5V
and for that matter, i don't recall the distributor needing the resistor. a stock distributor is just a switch. I believe it's the stock coil that demands the lower voltage
Old Jun 23, 2010 | 08:15 AM
Starfury's Avatar
Starfury
Actually, it's there to save the points. Running points at 12V will burn them up in short order. BUT, because the coil is designed to run on 7-8V, it's not a great idea to feed it 12V either. It could overheat it and turn it into a small bomb in your engine bay.
Diode Dynamics
28
May 26, 2022 12:02 PM
CubanoGT
Oct 2, 2015 10:29 AM
cbird1177711
Sep 3, 2015 08:43 PM
HIS S-197
Aug 10, 2015 05:47 PM
P Zero
Aug 15, 2006 07:00 PM
