ballast resistor
Old Jun 18, 2010 | 01:56 PM
mstngsule68's Avatar
mstngsule68
Default ballast resistor
what ballast resistor do i need for just the stock 68 points dizzy? and what resistors do i need to just build one myself?
Old Jun 18, 2010 | 04:46 PM
2+2GT's Avatar
2+2GT
None. The factory under-dash wiring harness has a resistance wire built in.
Old Jun 18, 2010 | 04:52 PM
mstngsule68
im not putting the factory harness in. so thats why i ask, otherwise yea i know its already built in. what voltage does the coil need to see while running and what resistors do i need to just make my own or would that not work.
Old Jun 18, 2010 | 07:40 PM
Starfury's Avatar
Starfury
Any good auto parts tech should be able to find you a resistor that will work. Most places should have one on the shelf. I don't have any books at home or I'd give you a part #.
Old Jun 18, 2010 | 08:05 PM
2+2GT's Avatar
2+2GT
IIRC, about 7V. During start, the resistor should be bypassed to provide 12V. Do you have a Factory Service Manual?
Old Jun 19, 2010 | 12:02 AM
mstngsule68
i have a haynes..........
Old Jun 19, 2010 | 05:41 AM
2+2GT's Avatar
2+2GT
Very carefully remove each page, and gently line your mulch pile with them while the Factory Manual is coming in the mail. The FSM is that much better.
Old Jun 19, 2010 | 10:27 AM
Starfury's Avatar
Starfury
LOL Funny, but true. Get the FSM. It's worth every penny, and more.
Old Jun 19, 2010 | 05:32 PM
mstngsule68
so really as long as i knock the voltage down to right about 7volts running that should work........how many ohms resistor would i need?
Old Jun 20, 2010 | 02:29 AM
mstngsule68
bump.
