'66 Mustang Project Advice
Old Jun 24, 2010 | 09:24 PM
Fishrmn703's Avatar
Fishrmn703
Default '66 Mustang Project Advice
Hello, I am new to this forum and this is my first post, so I hope I have posted in the right place. I have recently purchased a ’66 Mustang Coupe that has been partially restored/modified. Since this is my first leap into First Generation Mustangs, I have a few questions I hope you can help me with:
1.) How do I determine what type/model/year 302 engine I have? Serial # or ?
2.) I know that ’66 is not exactly a new car, but it seem to be quite Squeaky/Creaky. Is this normal? I think the bushings are dry, and I don’t think a firewall is installed yet. Does anyone else have this problem or know what it could be?
3.)The previous owner started the restoration but did not finish. From what I can tell, the engine is a 302, probably stock heads, Edelbrock Pro Flow EFI, 9” locking rear end with freeway gears, and Headers. Interior hasn’t been touched. So in addition to completing the interior I would like to finish the engine off as well. I would ultimately like the motor to push 350+ horsepower. Can anyone recommend a Head/CAM combo?
4.) Any good website recommendations, as I will most likely do the work myself – and this too is new to me : )
Any advice is appreciated. Thanks.
Old Jun 24, 2010 | 09:44 PM
2+2GT's Avatar
2+2GT
You need to look at the casting codes on the engine block. It's barely visible above the starter.
http://mustangtek.com/block/images/C8OE-6015-A_26.jpg
Normal, when not maintained properly. Most of the squeaks are the upper control arm shaft. One grease fitting at each end, four total. That should cure about 90% of your squeaks.
Even the stock heads will get you into the 325-350 range with simple port-matching and cleaning bumps out of the exhaust ports. On cams, I tend to be 'old school', the C9OZ-6250-C is a hydraulic version of the 289HP cam, and was designed by the guys who designed the engine. Personally, I'm running it's daddy, the original C3OZ-6250-C 289 HP cam. Solid lifters. You could also use the C7FE-6250-A Cobra LeMans cam. That's not just advertising hype, Ford actually used it at LeMans. Strangely, it's a streetable cam.
You'll want to do the "Arning/Shelby" drop at some point, as described here, it'll feel like a whole different car after you do that:
Arning/Shelby Suspension Drop
You'll also want to collect catalogs. My personal favorite:
http://www.mustangbarn.com/catalog.pdf
Old Jun 26, 2010 | 10:58 PM
Fishrmn703's Avatar
Fishrmn703
Thanks for the advice. I'll take some pictures and post them. Is there a way to match up stock 302 motors to each year to see the stock HP ratings?
kiwi4100
Aug 18, 2015 10:45 AM
MusBBad95
Aug 17, 2015 09:39 PM
kiwi4100
Aug 16, 2015 08:39 PM
daytooday
Aug 11, 2015 09:22 AM
