spongey brakes
I installed a new dual bowl master cylinder (manual brakes) this AM to replace my leaky old one. I used a 78 Granada MC as I have the LGV front disc conversion on my '66 coupe. We bled the brakes really well and only have clear new fluid coming out, but they still feel a little soft. Maybe it's just the new MC? It bolted right up but I did notice it was a bit thinner than the one I took out. The car stops fine but I have to push the pedal pretty far. Is this just the way manual brakes are? I can't think of much else to do to make them a bit "tighter" other than maybe adjusting the rear drums.
While I had access to my buddy's lift I installed my subframe connectors while I was at it. The car does handle noticeably better now- not so springy over bumps and turns tighter it seems with less body roll.
Tim
Well, I guess that I just have a smaller bore MC! No bleed down or loss of pressure. I drove it around all day yesterday and had no problems stopping, just had to press the pedal further than I am used to. Thanks guys.
You say you have front disc brakes, do you have a proportion valve plumed into the rear breakline? drum brakes take less pressure to apply than disc brakes. Without adjusting the pressure, the rear drums are at full pressure before the front discs which could cause the spongy pedal. I felt this right away when I installed my discs and was adjusting the valve. You have the find the right balance.
I didn't just install the discs, I've had them for a while. I just replaced the MC. And yes, I do have a proportioning valve. I drove the car around today and again, no problems, just have to press the pedal a bit further than I used to.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:42 PM
