Strange Engine Problem
Old Jul 11, 2010 | 08:05 PM
Aussie66Fastback's Avatar
Aussie66Fastback
so it happens from dead cold too or only after the car is warmed up and turned off a while?
Old Jul 11, 2010 | 09:28 PM
67mustang302's Avatar
67mustang302
That's called "it has a carburetor." They need time to get to NORMAL operating temperature. When cold they need to warm up, when sitting after hot they need to run a bit to get the fuel and heads back to the right temp.
Old Jul 11, 2010 | 10:46 PM
jonward786's Avatar
jonward786
lol please, if this was a simple issue of "the car is warming up" i wouldnt have posted. ive owned the car for quite a while. its electric choke functions flawlessly. what im saying is how can the engine shake and feel like its running on 6 cylinders for a few minutes and then all of a sudden miraculously bring itself back into its smooth normal idle.
and no, each time its done this it has been a hot start, i.e. driving around for 30 minutes, park somewhere for short while like the grocery store, go back out and it acts up. only this time it didnt correct itself.
its exactly the same sound and feel that it was when it had 2 bad spark plugs. so needless to say, that was the first thing i replaced when trying to diagnose this. new plugs, new wires, new coil, new fuel filter....nothing.
Old Jul 11, 2010 | 10:49 PM
67mustang302
So you're saying the problem is NOT going away now? If that's the case then it's fuel related(you already ruled out ignition). Change filter, rebuild carb etc. Are you sure the pump is working properly?
Old Jul 11, 2010 | 11:08 PM
jonward786's Avatar
jonward786
exactly, every other time its done this by some act of God it just fixes itself, so ive just ignored it. but this time it didnt fix itself. when i look down into the carb and blip the throttle i see 2 very healthy squirts.
Old Jul 11, 2010 | 11:13 PM
Aussie66Fastback
Jon mentioned possible issue with the pertronix. They are just an electronic swap out for points arent they?? (I've never actually seen one). So no points but you still have a distributor cap? Have you checked it and the rotor?
it sure sounds like fuel vaporisation from the way it does it after everything is heat soaked.
What carb is on it and do you have a spacer under it? does it actually start easy (or as per normal) or is it reluctant to start as well?
Old Jul 11, 2010 | 11:21 PM
jonward786's Avatar
jonward786
it starts very easily, as it always does. i thought it was heat related too but since it is still running poorly after sitting in my cool garage for a day now im not so sure.
its a holley 570 and i have a 1" phenolic spacer under it. i wish i had a spare pertronix unit to throw in there but i dont and of course no one is open on sunday
Old Jul 11, 2010 | 11:36 PM
Houndstooth's Avatar
Houndstooth
Do you still have your old points? You could try to switch those in to see if the Pertronix is the problem (I'm assuming you were talking about the Ignitor and not Flame Thrower). I kept mine when I switched in my Ignitor just in case. My car did this to me when the points were bad before I put in the Ignitor but I don't remember if it only happened when the car was hot.
Old Jul 11, 2010 | 11:38 PM
67mustang302
Have you pulled the fuel lines off the carb and checked the bowl filters at the inlets for trash? Look for fuel clogs or evidence of trash. You may need to do a rebuild if it got crud in it.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
