old suspension
Old Jul 15, 2010 | 02:28 PM
1967coupeon101's Avatar
1967coupeon101
Default old suspension
Is there any danger in leaving old suspension in a car?
When driving over bumps, the front suspension will sometimes let out a crack - not as if anything is snapping or breaking, just that its old. If OK, I just want to replace the springs and shocks.
Would anyone advise against this idea?
Old Jul 15, 2010 | 04:03 PM
69mach1377's Avatar
69mach1377
43 year old suspension...what could possibly go wrong?
Old Jul 15, 2010 | 04:26 PM
kalli's Avatar
kalli
lol ... well a creeeeeekkk is pretty normal when it'd dried out, needs greasing/replacing. a crack is bad. find the source, replace worn bushings, rubbers and joints
Old Jul 15, 2010 | 04:58 PM
Lumbergh's Avatar
Lumbergh
Depends on the condition of the suspension. Mine is still stock, but last year I replaced just about every part of the suspension you could name except the springs themselves and the sway bar. If it was a wear item, it was replaced. It's not that hard, though some parts will refuse to come off without the proper persuasion, and it did kind of tickle my insides a bit while working around the compressed spring, which literally has tons of force stored in it when compressed, while replacing the A arm. A major concern with these classic Mustangs is the condition of the shock towers. They withstand a lot of stress and are noted for cracking.
Old Jul 15, 2010 | 05:37 PM
jlg2002's Avatar
jlg2002
Like Kalli stated, a creaking noise is usually a dry bushing and or ball joint. The uppers are metal on metal with a grease joint doing the lube - If it goes dry it ain't pretty. Sounds like its time for a grease job a the least.
Old Jul 15, 2010 | 07:26 PM
1967coupeon101
yea, unfortunitely I was expecting these answers. I was hoping to avoid re-doing the suspension, this is actually for a falcon. I did an entire rebuild on my mustang and thought I could get away with it here.
its definitily stock, in fact the whole car is but its been outside most of its life - by the pacific :/ and theres some surface rust and wear. I'll try the grease, and if that doesn't do it, then I'll replace it all.
Thanks
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
