clutch pedal assembly
Old Jul 15, 2010 | 07:43 PM
1967coupeon101's Avatar
1967coupeon101
Default clutch pedal assembly
I got a complete 4 speed toploader kit from a shop in WA, and everything is fine except the pedal assembly. I can not get the clutch pedal rod to go through the brake pedal assembly and out the other side to put the clip through the hole in the clutch pedals rod.
I hope you know what I mean. Am I doing something wrong? I push and push and it wont go through all the way, even though theres no more room for it on the other end, toward the clutch pedal. I need about 1 cm more to stick out to access that little hole for the clip.
Any ideas?
Old Jul 15, 2010 | 08:52 PM
2+2GT's Avatar
2+2GT
Any ideas?
Call your supplier. You may have the wrong pedal. How long is the shaft on this pedal?
Old Jul 16, 2010 | 01:43 AM
1967coupeon101
well its all from a 67, which is what I have, so its the right one. i just cant get it all the way through
Old Jul 16, 2010 | 02:47 PM
2+2GT's Avatar
2+2GT
Well, you said it was all the way in on the LH side. Is it?
Old Jul 17, 2010 | 09:26 PM
1967coupeon101
yes, it is as far as itll go
Old Jul 18, 2010 | 08:11 AM
2+2GT's Avatar
2+2GT
If the pedal shaft is all the way in, and does not stick out the other side, you either have the wrong pedal or the wrong pedal bracket. How about a nice photo?
Thunderball
15
Nov 22, 2015 11:49 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
