Suspension and Steering is finally finished!
Old 07-22-2010, 08:25 AM
Starfury
Starfury's Avatar
Pooty, lots of people have complained about ride height with M+'s standard-eye "stock ride height" leaf springs. That doesn't look like stock ride height to me.
Starfury is offline
Old 07-22-2010, 07:32 PM
Aussie66Fastback
Aussie66Fastback's Avatar
iirc stock ride height on 65/66 is 26" measured in the center of the wheel arch
Aussie66Fastback is offline
Old 07-23-2010, 11:23 AM
paddy187
paddy187's Avatar
Maybe the back will settle with more miles, I do think that is not stock height like others have said. But if you like the look that what matters.
paddy187 is offline
Old 07-23-2010, 11:56 AM
AGShelby
AGShelby's Avatar
Default Spring compressor
Originally Posted by nba1341
Very nice I need to replace my drivers uca but don't know how to use a spring compressor and want someone with experience with one to help me
I have done 4 spring replacements - and just taught myself how to use one, along with some tips in the online forums. I just check out the tool from Pep Boys or Part Plus - have never bought a compressor.
The ones that work best for me are the ones that grip from the inside. I have used the external gripping ones 2x, and find it difficult to adjust with enough "bite" before the threads hit the top of the shock tower.
One piece of advice that I have found helps is to remove the sheet metal cover inside the wheel well. Taking this cover out gives you more room to work and you don't have to compress the spring as tight to get it back in.
If you go back with shortened coils there is not much compressing required - it is easy to get them in.
I suggest you give it a try - it isn't that difficult.
AGShelby is offline
Old 07-23-2010, 12:01 PM
AGShelby
AGShelby's Avatar
Your car looks great - nice work.
I suggest you check into CSRP disc brake conversions. I just put a set on my car and the kit was complete, high quality and a quick install.
AGShelby is offline
Old 07-23-2010, 12:10 PM
paddy187
paddy187's Avatar
nba read this http://home.bresnan.net/~dazed/spring and there is a guy on ebay who makes the one described by daze. I used a claw type and was very careful and I need to make a spacer and cut the bolt in the centre so as not bottom out on the upper arm/perch
paddy187 is offline
ctgreddy
10-14-2015 09:05 PM
stark777
09-21-2015 12:46 PM
uberstang1
09-20-2015 06:42 PM
09-08-2015 11:50 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Suspension and Steering is finally finished!
