1966 Mustang Fastback, 514 cubic inch engine?
Hey guys,
What is the biggest engine you can put in a 1966 Mustang Fastback?
514 CUBIC INCH – 625 HP FORD RACING PERFORMANCE CRATE ENGINE ASSEMBLY?
http://www.fordracingparts.com/parts...tKeyField=6188
RE: 1966 Mustang Fastback, 514 cubic inch engine?
It depends on how much work you are willing to do.
That motor will not fit with the stock engine compartment, which means, it won't fit with stock style suspension or steering. Need to remove the shock towers, add coil overs or Mii type setup.
351w or c based stroker (427 comes to mind) is the largest displacement you can fit as fas as I know without front end surgery.
I will be more than happy, just answer these 3 simple questions:
What is your usage goal for the car?
What is your performance goal for the car?
What is your budget for the car?
My goal to have a high performance street/strip beast! Run the 1/4 under 11 seconds and act like their is no budget but just enough to get this engine to drop in nicely.. Lets say I have 10gs just for the engine to fit in, not 10gs for the engine itself..
ORIGINAL: ChaseVarnado
347 with a power adder will run 9s in a 65-6.
You need to spend the money in the rear, tuning the suspension, bracing the body, and buying tires.
ShaneB26154
35
03-04-2021 04:05 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
