Trans Leak Help
Old Aug 2, 2010 | 09:24 PM
mitchdakid's Avatar
mitchdakid
Default Trans Leak Help
my 67 with an aod in it is leaking from where the driveline connects to the transmission. First time it has ever done this, any help is much appreciated. Thanks
Old Aug 2, 2010 | 09:34 PM
Gun Jam's Avatar
Gun Jam
not real familiar with the AOD but i bet they are all the same.
Remove the drive shaft
use bucket to catch all the oil that comes out
use thin blade something to pry out oil seal
Use socket to tap new oil seal in
replace DS
Replace fluid.
I bet thats how it goes.
-Gun
Old Aug 3, 2010 | 01:15 PM
Randys66gt's Avatar
Randys66gt
Gun Jam is right!!! Don't forget to check the slip yoke too. I have seen some that the bad seal has ground a groove into the slip yoke and that was also part of the prob.
Old Aug 5, 2010 | 03:37 PM
mitchdakid's Avatar
mitchdakid
Could this have just gotten old, or could it be a problem with too much torque or horsepower over time. I was going about 80 for an hour, first road drive in awhile, otherwise just in town.
Old Aug 5, 2010 | 04:28 PM
Gun Jam's Avatar
Gun Jam
probably just old...sitting for extended periods doesnt do them any good either.
-Gun
Old Aug 8, 2010 | 08:53 PM
mitchdakid's Avatar
mitchdakid
-Gun
Pulled it easy enough, any hints or tricks to getting the new one in?
Old Aug 8, 2010 | 09:20 PM
2+2GT's Avatar
2+2GT
Use a seal driver or large socket to drive it on evenly.
Old Sep 10, 2010 | 04:25 PM
mitchdakid's Avatar
mitchdakid
Still leaking pretty bad, any other ideas??
Old Sep 10, 2010 | 05:06 PM
Gun Jam's Avatar
Gun Jam
replace the slip yoke and the trans seal again.
But before you do check for play...does the slip yoke move up and down, left and right quite a bit when you push on it? Did you notice any burs or rough spots on the slip yoke where it touches that oil seal?
Are you sure you didnt damage the oil seal when installing it?
IF: There is little or no play in the slipyoke where goes into the trans
AND you know the slipyoke is fine and not roughed up
AND you are sure the oil seal is not damaged
THEN: its not leaking from the tailshaft oil seal...perhaps its running down the top of the trans and simply dripping off the end of the tail housing...
Let me know what you think about those ideas.
-Gun
Old Sep 10, 2010 | 06:49 PM
Randys66gt's Avatar
Randys66gt
Just like Gun Jam and I said....... check the slip yoke cuz there is nothing else.
jerrytubes
Oct 23, 2015 12:11 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
