reverse light removal 67 coupe
Old Aug 24, 2010 | 02:47 PM
MustangFTW
Guest
Posts: n/a
Default reverse light removal 67 coupe
hey guy have seemingly simple problem here
both my interior and one reverse light are burned out i got the interior one out fine, but the reverse one doesn't want to come out..... i tried pushing then twisting since thats how most light bulbs on the car are but no dice couldn't get it and don't want to break it.
Old Aug 24, 2010 | 03:17 PM
Jonk67's Avatar
Jonk67
It's probably froze in the socket from corrosion. Try spraying as close to the socket as you can with some lubricant, WD-40, etc. The bulb does push in slightly and turn to come out but they get stuck after 40+yrs.
If you push on the bulb use a rag or something as it can break and cut you. If it breaks they pick as much out as you can then use a med. sized needle nose to push on the center of the bulb socket and twist then pull it out with the pliers. Be sure to only grab/twist the bulb/base as you don't want to wreck the socket. If the socket is ruined or gets ruined there are replacements at the parts store.
When you get the bulb out you can always test the socket with a 12V test light (<$5). When you put the new bulb in put a dab of wheel bearing or other thick grease on the socket so it won't freeze up a again, I do this to all the bulbs I change, really saves a headache down the road.
Jon
Old Aug 24, 2010 | 05:12 PM
MustangFTW
Guest
Posts: n/a
nice ill try this right away
Old Aug 24, 2010 | 06:39 PM
MustangFTW
Guest
Posts: n/a
hmm ive sprayed around the bulb with WD-40 but it doesnt want to get pushed in at all it wiggles around but nothing else. im almost to the point were im going to break it just so i can go at it with a needle nose.
Old Aug 24, 2010 | 09:13 PM
Jonk67's Avatar
Jonk67
It may come to that, after breaking the bulb I usually put the needle nose into the shell of the bulb, spread the pliers and use the tips to press outward and turn to unscrew the base. At worst you may have to pinch the sides of the bulb base in to collapse it and release the nubs from the socket and pull the base out crushed. Someone may have put the wrong bulb in or fudged up the little nubs that twist into the socket. The bulb should be a single filament #1156.
If it doesn't push in at all the spring in the socket may be rusted solid and you'd have to replace the socket anyway to fix that. Once you get the base of the bulb out, if the socket looks ok you can just replace the internals, they look like this:
Jon
Old Aug 25, 2010 | 10:40 AM
MustangFTW
Guest
Posts: n/a
thanks, ill be trying this today.
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
amandahchase
Sep 3, 2015 10:09 AM
