carb help
Old Aug 27, 2010 | 07:13 PM
crunchytator's Avatar
crunchytator
Default carb help
I have a stock 289 with a 351 windsor cam. I was wondering if the motorcraft 4100 will work with it. also how many vacum ports should i have on the 4100? Its in a 66. It originally had a 2 barrel. Are there any issues or changes with this setup or should it basiclly be a bolt on?
Thanks
Old Aug 27, 2010 | 07:18 PM
2+2GT's Avatar
2+2GT
Thanks
Two ports. Ported vacuum on the lower right, and ambient air above the choke (some don't have this). There is also the hot air connection on the choke. The PCV connection is on the rear of the carb spacer.
You should have no issues using the 351W cam on the 289, it's just a little warmer than stock, no where near the 289HP cam. Remember to use the 351W firing order, though.
Old Aug 30, 2010 | 01:07 PM
crunchytator
Thanks for the info. that helps
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
