NEW MOTOR DILEMA!!!
Old Aug 29, 2010 | 05:02 PM
drewsky's Avatar
drewsky
Default NEW MOTOR DILEMA!!!
Ok so i posted few days back stating that my flywheel or tq converer may be loose making noise. found out that wasnt the case. Got underneath the car earlier when it was running and put my head right up against the oil pan. Its in there!!! something is knocking around unfortunatly. This is a brand new build and i havnt rapped it up at all! it prolly has 3-4hours of run time total and this is a huge letdown.
So Im almost positive it isnt a rod knock. the lower the rmp the louder it is if i rev it a little it is not there. it almost sounds if my oil pump is loose or there is a wrench or something in there! im confused and very dissapointed. what do you guys think it could be?!
The motor is a 351w. btw
Old Aug 29, 2010 | 05:03 PM
drewsky's Avatar
drewsky
mabe fuel pump installed wrong? it works just fine but mabe the pushrod that pumps it? just a thought
Old Aug 29, 2010 | 05:24 PM
2+2GT's Avatar
2+2GT
Um, the Chevy has a pushrod. Still, it's easy to check. Remove the pump. The engine will stall from lack of fuel in under a minute, but by then you'll know if it's the pump. If not, you'll have to pull the pan.
Old Aug 29, 2010 | 05:55 PM
Gun Jam's Avatar
Gun Jam
maybe he means the oil pump...I kinda doubt that an oil pump would make noise like that.
Drop the pan and have a look I guess.
-Gun
Old Aug 29, 2010 | 06:17 PM
67mustang302's Avatar
67mustang302
I'd pull it. Could be a nut/bolt wasn't properly tightened on a rod, or a piece of hardware left in it etc. Whatever it is, if it's rattling around inside the pan, you want to be sure.
Old Aug 29, 2010 | 07:05 PM
drewsky's Avatar
drewsky
im gonna have to pull the pan off. look whats going on. its a strange sound but it cant be rod knock... i really dont want to pull it i just put it in....... ehhhhhhhhh
ok yah pushrods push the lever on chevys haha wasnt thinking
Old Aug 29, 2010 | 07:29 PM
JMD's Avatar
JMD
Didn't you have a shop rebuild the engine?
I seem to remember it that way, if so, if the shop put the pan on check with them before dropping it, you will want them to stand behind their work.
Noises like these are very hard to isolate no matter where it sounds to be coming from, and since the pan is thin, most any heavy metallic noise will sound like it is coming from the pan. I would tend to concentrate on the bell housing area, cracked flex plate, etc.
Incidently, last time I heard a bad sound coming from a new engine, my brother in law had "secretly" dented the oil pan into the crank... he failed to mention this fact before he decided to ship the engine all the way to NC to be "fixed", what a dumb ***.
Old Aug 29, 2010 | 11:38 PM
drewsky's Avatar
drewsky
cracked flex plate crossed my mind a well. im gonna give the machine shop a call tomm.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
