1968 Running Great
Old Aug 13, 2005 | 01:33 PM
KLS1968STANG's Avatar
KLS1968STANG
Default 1968 Running Great
I've been posting some threads about my 289 RUNNING HOT.. got beyond all that when the machine shop reworked the right head. The stock trans is a 3 spd in the floor and i'm wondering what life would be like with a TREMEC 5 spd and nice shifter installed.
Has anyone ever had any experience with this? Does the TREMEC fit pretty painless or does it require a lot of mods? Would the change make a difference in power/transfer to the rear wheels in a manner that I could notice?
Also around 65 MPH the car stocks vibrating. Could this be balancing of the tires or what else?
thanks,
KLS
[IMG]local://upfiles/18859/D035F7E0EC474F3DB75DD02DA56F5F69.jpg[/IMG]
Old Aug 13, 2005 | 05:02 PM
68COOP's Avatar
68COOP
Default RE: 1968 Running Great
That, or you have a bad uni joint getting ready to go. If you go with the T5, you might have to alter the hump for Reverse, I THINK, but it's not a big deal. Nice Coupe!
Old Aug 13, 2005 | 06:12 PM
69mach1377's Avatar
69mach1377
I think the T5 is a good fit, but a Tremec is larger and may not fill well.
Old Aug 13, 2005 | 11:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
I agree with Daniel..the T-5 or even an old top loader would be a much easier choice. However, unless you change the rear gears, the 3 speed will be running the same RPM's at 65 as either one one of these. Your vibration could be a myriad of things. Either the U-Joints as mentioned, or imbalanced tires, or just worn out bearings etc. Jack it up and shake the crap out of everything to see if you can locate the problem. Grease your front wheel bearings, and grease the zerks all around, to include the U-Joints.
Old Aug 14, 2005 | 12:30 AM
66 Hardtop 5.0's Avatar
66 Hardtop 5.0
ORIGINAL: Soaring
Soaring, I`m sure this is what you meant to say...
It will be the same RPM at 65mph with the C-4 or Toploader, but the RPM will drop with the T-5 since the 5th gear has a 0.63:1 ratio
Old Aug 14, 2005 | 02:05 AM
69mach1377's Avatar
69mach1377
Vibration source could also be from an unbalanced drive shaft...
Gary Ugarek
63
Dec 11, 2015 02:01 PM
jc1
Aug 29, 2015 07:09 PM
movielover40
Aug 27, 2015 10:13 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
Pain.
Aug 7, 2015 10:48 PM
