I need help guys
Old Oct 26, 2010 | 10:38 PM
001mustang's Avatar
001mustang
Originally Posted by Starfury
He mentioned the CSRP Granada kit in his original post.
Sorry Star.
I'm drinking too much punch also.
I got you mixed up w/ phatboy.
Hoping phatboy will consider 390 big block and OEM 4 piston KH calipers.
Old Oct 27, 2010 | 06:57 AM
tx65coupe's Avatar
tx65coupe
Originally Posted by 001mustang
Right. No way I would loose the 390 big block.
I dunno why one would want granada brakes???
Maybe its time for us to have a long talk with phatboy; maybe phat had too much punch.
There is nothing wrong with Granada brakes. I have them on mine and they work great. I know several people that have them. The factory style front discs may be a little better, but I don't see whats so bad about them.
Old Oct 27, 2010 | 09:25 AM
fordmus67tang's Avatar
fordmus67tang
I agree with tx65coupe. I have granada brakes as well and they are fine.
Old Oct 27, 2010 | 09:42 AM
001mustang's Avatar
001mustang
Nothing is wrong w/ granada brakes. Simpler one piston design, easier to troubleshoot, and likely more reliable. Granada brakes should have less unsprung weight. If find a donor car they can be very cheap to install.
The 4 piston OEM KH is much easier to install. You don't have to change spindles. You don't have to change tie rod ends. You don't have to align the front end. Increased piston area equates to more stopping power. I plan to change fluid often in hopes to prevent sticky pistons. My pistons are chrome plated which is an improvement over OEM pistons. SS pistons are available.
Old Oct 28, 2010 | 04:19 AM
tx65coupe's Avatar
tx65coupe
Thats true. The OE style is easier to install. The Granada spindles are beefier than the stock ones though. I liked that. I say either are a good setup.
Old Oct 31, 2010 | 09:33 PM
Itsa 66's Avatar
Itsa 66
There seems to be a lot of vitriol out there for the Granada set up. Not so much here as on one of the other forums where I swear a certain member must get an email alert every time the word "Granada" is used so he can jump in and spew!
I have read many posts from people who use 'store bought' kits that dump on the Granada setup and many posts from people who actually use the Granada parts who say that it works fine, no problem.
I realize that there are issues caused by altered geometry with the Granada stuff, but they are not really that difficult to overcome. When I first looked at the 'store bought' kits they were way more expensive than the used parts I picked up for the Granada setup. Eventually I did have to buy quite a bit more suspension parts but my 66 was in pretty lousy condition and rebuilding the front suspension top to bottom was not really an option. I would have had to do the same rebuild even if I did buy from CSRP or one of the other companies. I'm pretty sure it will still end up being considerably cheaper going the Granada route, which seems to be the only real reason for doing it that way.
Old Nov 1, 2010 | 06:03 AM
tx65coupe's Avatar
tx65coupe
The only issue I had with the Granada spindles ins the steering bump stops. I had to grind them down some.
v8sn95
Sep 7, 2015 10:17 AM
Mustangmalo
Sep 6, 2015 05:22 PM
SilverStallion05
Sep 5, 2015 10:48 AM
Emblazoned
Sep 3, 2015 10:45 PM
