Vacuum on 302 Engine
Old Sep 11, 2010 | 09:59 PM
jaedwrds's Avatar
jaedwrds
Default Vacuum on 302 Engine
I recnetly rebuilt my 302( only 25 miles on it). I checked the vacuum yesturday and it was at 10 which i thought it was supposed to be at 20. I checked it out of the fitting in the back of the manifold that the tranny connects to which could be why it was low. I dont know where to connect the vacuum gauge though if its somewhere else. Any Ideas
Old Sep 12, 2010 | 08:48 PM
KBunny's Avatar
KBunny
Does it hold a solid 10lbs or does it move around? Have you checked your timing on your Dis? What about carb adjustments, have you done any?
Old Sep 13, 2010 | 01:45 AM
67mustang302's Avatar
67mustang302
What cam/head/intake combo does it have, and what compression?
Old Sep 13, 2010 | 02:32 AM
jaedwrds's Avatar
jaedwrds
its a pretty steady 10lbs.....the cam is a sealed pro CS108R is number. I have edelbrock air gap manifold and edelbrock rpm heads. The compression im not 100 percent on but id say 9.5 the bottom end is rebuilt and stock. I have messed with timing and carb tuning and it still reads 10 so idk if my engine needs to break in more or whats up. I didnt torque my carb to 60 to 80 pounds but i feel thats way to much torque for that carb.
Old Sep 13, 2010 | 02:56 AM
67mustang302
What's the ignition timing at while idling? A setup like that would be lucky to make 15" at idle. Chances are with some timing and idle mixture changes you could get to your ideal idle and see like 13-14" at idle.
Galactic
Apr 29, 2019 02:56 PM
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
