Choke Stove repairs?
Old Sep 13, 2010 | 11:39 AM
AgDelt03's Avatar
AgDelt03
Default Choke Stove repairs?
Has anyone had experience making repairs to a choke stove/choke tube?
Working on getting a 1969 302 up and running again and know that this task is easier with the manifold removed, but would like to make what repairs I can so I can relocate the car to a more practical location before I start to dismantle it.
The hot air tube to the threaded inlet on the carburetor seems to have broken off from the top of the choke stove on the passenger side of the exhaust manifold. I know there are various kits and replacement tubes, but want some input on the simplest and most immediately effective fix. I have no plans to install a manual choke.
Try and drill out the top hole? Jut plug the holes on the carb and see if it warms up after awhile?
Old Sep 13, 2010 | 12:09 PM
2+2GT's Avatar
2+2GT
It'll never warm up by itself. Drill the stump of the old tubes out with a 1/4" drill. If you use a long one, or a drill extension, you can get to the lower hole with the drill next to the alternator.
Old Nov 12, 2011 | 01:29 PM
carguysx2's Avatar
carguysx2
I just bought a choke stove repair kit from Auto Zone online. It is made in Thaiwan and has no instructions. Not that many parts, and sure it's not "rocket science", but not self explanatory either! One thing that really confuses me is that it contains an inch long alum rounded piece that is smaller at one end than the other and it is solid, not hollow! And I cannot figure how any of it attaches to the housing piece that clamps to the exhaust pipe or manifold (I have hi-po manifolds and no hole for the heater pipe). Can any one help with this? A pic of the kit contents can be seen for this part 55111 at:
http://www.autozone.com/autozone/acc...ntifier=426073
Many thanks!
Old Nov 13, 2011 | 06:46 AM
2+2GT's Avatar
2+2GT
It's a generic set of adapters. You're not supposed to use them all. My guess on your pin is it's meant as a plug, to be hammered into a hole you don't even have. The stove clamps to the exhaust pipe, and the tube sticks into the hole, and connects to the choke.
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
yourmom6990
Sep 14, 2015 10:52 PM
rksnow1
Sep 14, 2015 08:46 PM
