Advice needed on Power brake booster
Old 09-16-2010, 01:55 PM
HEADACHEZ
HEADACHEZ's Avatar
Default Advice needed on Power brake booster
Okay so I am in the process of putting things back together on my 67 and first up is a power brake booster. As of now the car has manual drum brakes all around. I plan on putting power disc brakes up front and add rear disc at a much later time. I know I could just pick up a power brake disc kit online like SSBC http://www.ssbrakes.com/commerce/det....cfm?nPID=8306. However I won't need at the parts at this exact moment since I also will be replacing all of the steering and suspension as well.
HEADACHEZ is offline
Old 09-16-2010, 01:57 PM
jeffampt
jeffampt's Avatar
So what is the question?
jeffampt is offline
Old 09-16-2010, 02:01 PM
HEADACHEZ
HEADACHEZ's Avatar
Sorry. The question is I need recommendations on what is a good power brake booster to purchase. I would like to buy the power brake booster with master cylinder separate from the rotors and everything else.
Old 09-16-2010, 02:12 PM
jeffampt
jeffampt's Avatar
Not sure how far ya are going as performance wise, but here is a good option.
http://www.discbrakeswap.com/Mustang...s%20SWAP2.html
I think $800 for everything......
jeffampt is offline
Old 09-16-2010, 02:38 PM
HEADACHEZ
HEADACHEZ's Avatar
That kit is very tempting but I want to go with kit that's better than stock. However at this point I am only looking for a good power brake booster that will be able to perform well with an high perf. brake upgrade and will work with rear disc as well. Maybe this one? Not sure....
http://www.summitracing.com/parts/SSB-A28140/
Old 09-16-2010, 03:26 PM
mr_velocity
mr_velocity's Avatar
What are the pros/cons of swap1 vs swap2 vs swap3? Everyone always goes right for the granada kit.
mr_velocity is offline
motown girl
08-28-2015 08:21 AM
FD725
08-23-2015 06:43 AM
jpplaw
08-22-2015 09:29 PM
defarmer
08-13-2015 06:40 AM
FD725
08-11-2015 03:43 AM
Quick Reply: Advice needed on Power brake booster
